Results 1 to 4 of 4
Thread: Long and short fuel trim is not correcting fuel.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Some strange thing is happening. Here iz the video attached. Can you please have a look and give your opinion gents.
    Engine run smooth but reach afr 13.5 max. When switching gear become 10 or even less. Also, less than 10 when throttle to idle. When engine is working few seconds it is becoming max 12.5 - 13.5 again. Never 14.7 so far.
    Inpa shows short and long fuel trim does not correct. Short is always 0 & long is 1.0....
    <font color="#333333" style="color: rgb(51, 51, 51); background-color: rgb(228, 228, 228);">
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
    Jul 2004
    Houston, TX
    36 Cylinders
    Is it properly tuned? What errors are present?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    It is strange but no errors. Tuning file done by TTFS and it was working no problem. Even i did re instalation to different ecu the same file but no success. If you go to my yuotub chanel you can see that about month ago i had a problems with lyambda. Adaptation was working but lyambda was fail. Then changed lyambda and everything was ok.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Any idea?
  1. Long term fuel trim is affecting my WOT map fueling OBD1
    By dragon850 in forum Forced Induction
    Last Post: 07-26-2017, 01:20 PM
  2. Need help, radio and turn signal relay is not working
    By Kwaaahhh in forum 1996 - 2003 (E39)
    Last Post: 01-21-2007, 07:06 PM
  3. 540i and m5 wheel fitment is identical, correct?
    By The Fifth Element in forum 1996 - 2003 (E39)
    Last Post: 11-21-2006, 10:55 PM
  4. high revs and yet my tranny is not moving
    By clockwork in forum 1999 - 2006 (E46)
    Last Post: 07-01-2005, 01:39 AM
  5. The Long and Short Of It All
    By Ron17 in forum Off-Topic
    Last Post: 02-21-2003, 01:24 PM
