Results 1 to 3 of 3
Thread: M50TU Siemens Injectors
    Feb 2017
    Minneapolis, Minnesota
    1995 BMW 525i/5
    Lightbulb M50TU Siemens Injectors
    Hello,
    I'm looking at some Siemens 60lb injectors on ECS Tuning that are substantially cheaper than other sets of 6.
    My question is: is it an issue that they're not sold in a set? From my understanding, injectors are "matched" when sold in a set. Will this pose any issue with my build?
    Additionally, are the "short" injectors the correct size for the M50? The part number is INJ60HSS.
    Thanks!
    Apr 2006
    Minnesota eh?
    86 325es
    I think ECS has the wrong picture on there website. There is a short version of the siemens 60 lb injector.
    http://www.siemensdekafuelinjectors....e-short-style/
    You need the long version
    https://www.highflowfuel.com/i-23906628-genuine-siemens-deka-60lb-fuel-injectors-ev1-60mm-length-630cc-fi114961-1.html?gclid=CjwKCAiAmb7RBRATEiwA7kS8VMsQ7X_rX3bUz G1RkYbf1ZiT1w9-2n6eApztXkXO6L7g5vt3cCKJKRoCIRkQAvD_BwE
    These injectors are not matched in sets. That is only done if you purchase sets of EV14 injectors from certain injector companies. If the add doesn't say they are dynamically matched sets then they are not.
    Feb 2017
    1995 BMW 525i/5
    Great info as usual. Thank you sir!
    Sent from my Nexus 6P using Tapatalk
    '95 E34 525i, M50B32 (S52 Crank, K1 Rods, JE 9.0:1 Pistons, S52 Cams, Cutring, Achilles Oil Pump Shaft & Sprocket), GTW3684R 0.82A/R, ZF320
  1. m54b30 rotating assembly/24lb siemens injectors
    By yerbs in forum Engines, Performance Parts & Software
    Last Post: 04-25-2013, 07:06 PM
  2. Siemens injectors 83 lb/hr
    By sgubitosi in forum Forced & Chemical Induction Parts
    Last Post: 02-18-2011, 07:16 AM
  3. Siemens injectors on a bosch loom
    By DrWho in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-20-2010, 09:09 AM
  4. 55lb Siemens Injectors (6)
    By ienjoydrifting in forum Race Cars & Track Parts
    Last Post: 05-02-2009, 01:34 AM
  5. '95 M50TU Fuel Injector Pressure Rating
    By Frzninvt in forum 1988 - 1996 (E34)
    Last Post: 10-04-2008, 08:14 PM
