Results 1 to 25 of 29
Thread: Turbo E36 round 3 V2
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    guess ill make a build thread again for my car.
    Stock M52 with cutring head gasket and ARP head studs s52 cams.
    RK Tunes e85 115# tune.
    S366 with a 3.5" downpipe to 4" after manifold out back to Aero Turbine muffler.
    Car made 663WHP and 623ftq at 24psi, but boost controller is a bleed style so at 5500RPMs it dropped to 21psi or would have made over 700whp.
    Car worked for almost 2 years as is, but ive gotten into way more drag racing. Car now has 210mm Diff with Butter's built axles. I sold the euro 6 speed and got Perrys GM trans adapter plate and picked up a th400 as well as some spray. I also got rid of the stock DME and picked up a ms3pro and getting an obd2 jumper harness made.
    Now some pics of my junk.
    this is a before when i got it and how it sits today, besides the front RTS.
    then just a random bunch of pics.
    Follow my builds on youtube and IG.
    www.youtube.com/thenameskam
    @thenameskam on IG
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    @thenameskam on IG
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    @thenameskam on IG
    Aug 2012
    CT
    Twin turbo LS E36 M3
    this thing is gonna rip
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
    Apr 2006
    Minnesota eh?
    86 325es
    Welcome to the 9's
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Always loved this car brother.
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Quote Originally Posted by dburt86 View Post
    lol
    Welcome to the 9's
    I dont count chickens!
    Quote Originally Posted by E36 HateR View Post
    likewise my man!
    @thenameskam on IG
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    What was your best et and mph with that setup?
    PTE6262 .63 A/R, Stock S52, Cutring/Copper Spacer/Arp Studs Combo, Water Methanol Injected
    10.9@131mph. #AngerMotorsports
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    I only got one decent run in on wastegate which was 600 wheel. I ran a 7.2 @ 102mph with a 1.8 60 and no 2 step. I cut a low 1.6 60 but car shut off due to low fuel and starved the pump lol
    @thenameskam on IG
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    really dont want to. but looks like im going to have to remove my vader rain interior to put in a cage for safety.
    @thenameskam on IG
    Apr 2006
    Minnesota eh?
    86 325es
    Why can't you keep the interior and have a cage? My car has a full interior minus the carpet. I ditched the carpet because it was heavy but there is no reason I couldn't put that back too. Only other thing I lost was the map pockets because they hit the door bars and I was too lazy to go around them.
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    The bulkhead in the rear is right behind the arms on the seats. Was told that's where the cage needs to tie into the rear to be "safe"
    @thenameskam on IG
    Apr 2006
    Minnesota eh?
    86 325es
    not sure what you mean but this is mine
    Nov 2013
    Hager City, WI, USA
    1994 BMW 325is Coupe
    What manifold you got bolted to that beauty?
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Quote Originally Posted by boostedbim View Post
    Running Otis's Rapid spool mani.
    Perry, this is the bulkhead on the e36. Granted, per NHRA I can bend the down bar and point it down the rear decklid and run it to the rear frame rail but was told it's nowhere near as strong as tieing it into the rear bulkhead.
    @thenameskam on IG
    Aug 2012
    CT
    My biggest regret with my car was not going full retard. I should have stripped it, and shaved as much weight as possible. It easily could have gone 5.50s with just some weight out of it.
    And lets be honest, the nicest E36 interior is still garbage.
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    @thenameskam on IG
    NY/FL
    '08 G35S, '98 M3/4/5
    I can't exactly see, what PSI were you making those numbers on the dyno?
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
    NY
    skateboard
    Quote Originally Posted by Kame36sedan View Post
    Send them over to me for safe keeping, or trade for a skateboard.
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Quote Originally Posted by Da Infammus 1 View Post
    It's not graphed. Made 600 at 20psi made the 663 at 24psi. This is all on an untouched rk tunes base maps.
    @thenameskam on IG
    Nov 2013
    VA
    E36
    This thing was a monster at h2oi
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    I always create build threads and never follow through lol. Here is an update.
    I pulled all the interior out to fix a horrible wiring issue.
    After that I decided to go ahead and install a 10 point chromoly cage since everything was already out.
    I ordered the gen x billet/bolted torque converter from ProTorque ( great guys).
    I ordered 4 of these fancy vanjen clamps to run as well as a tr1245 1000hp treadstone intercooler.
    I also ordered a BMW 6 bolt CV to 1350 adapter and a chromoly th400 to 1350 slip yoke both made by sonnax.
    @thenameskam on IG
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    I received my obd2 pnp adapter for my ms3pro, I will be running 1600cc injectors on the car as well.
    I also ordered the cx racing t56 trans mount for the e36. Derek ran the same with his th400 and it has adjustment slots for alignment so we are thinking it'll work fine.
    Also, anyone using an app for the forums? This site sucks for mobile browsers...
    @thenameskam on IG
    Virginia
    97' m52 turbo
    Tapatalk works okay. Better than mobile or bfc app for sure
    600-700hp on a stock m52... e85 is the shiz
    I really like the rain seats...
    Sep 2003
    plastination station
    I think thats my old car! Good to see the 'ol girl still out there boosting along :thumbsup
    "If you can leave black marks from the time you exit a corner till the time you brake for the next turn, then you have enough horsepower." --Mark Donohue
  1. E36 Turbo Photoshoot, Round 2.
    By MikeE36 in forum BMW Rides & Events
    Last Post: 06-11-2012, 05:04 PM
  2. E36 FS: 450rwhp Turbo E36 M3
    By southpaw in forum 3 series & Z Series
    Last Post: 10-04-2011, 02:28 PM
  3. E36 FS: 1997 AVUS Turbo e36 M3 511whp AEM
    By Mike185 in forum 3 series & Z Series
    Last Post: 05-29-2011, 06:31 AM
  4. E36 FS: E36 Dinan V2 Catback Exhaust
    By 1980corvette in forum Engines, Performance Parts & Software
    Last Post: 04-29-2011, 12:06 PM
  5. E36 Wtt 07 si for turbo e36 m3
    By aj906115 in forum 3 series & Z Series
    Last Post: 10-15-2010, 05:53 PM
