Results 1 to 11 of 11
Thread: Auto trans service?
    Jun 2016
    Los Angeles, CA
    M235 | M3 | 325Ci
    Auto trans service?
    So, my 2006 325Ci with 134,000 miles on it, has never had the auto transmission serviced. I was thinking of changing the fluid & filters, but I know some recommend that you not do this if it has never been done on a high mileage car. Any opinions on this out there? Should I do it, or just write it off since it was neglected too long? At this time, the transmission seems to work fine.
    Oct 2003
    Seattle
    99 M3
    Auto trans service?
    Just do it!! 134k isn’t that high of mileage.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Do it, do it professionally, and never question it again.
    MD
    BMW 328Ci
    You should definitely change the tranny fluid along with the filter, bolts and gasket. Your car will last forever, I did mine and it lasted forever. I had 382,000 miles and sold the car.
    High Mileage 325,xxx and counting...
    BMW runs in the family
    3-Series my whole life
    e30 325i / e36 328is /
    e46 323i / 328Ci / 330Ci / 335i E92 / E46 M3
    Jun 2016
    Los Angeles, CA
    M235 | M3 | 325Ci
    Quote Originally Posted by bmw328ciwa View Post
    Thanks for the input, and bumping your original thread! Now I feel confident and ready to do this, now the only problem is I noticed my gear selector shaft seal is leaking, so that needs replacing also. Probably have to lower, or even remove the trans entirely to deal with that...
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    BMW...GENERAL MOTORS 5 speed auto.... 2000-2005...325xi wagons....DO NOT CHANGE your factory TRANSMISSION FLUID....No atf for this BMW is available. Dexron 6 kills this transmission when used as a last resort.
    Aug 2014
    Lawrence Kansas
    Generalizations like that are counter productive to helping people, especially when its not true.
    ETL is no longer made but there are plenty of ETL rated replacement fluids out there with a very similar chemical profile. You don't have to stick to dex6. You can use castrol multi vehicle import atf as well as valvoline maxlife atf and redline d4. Or you can use dex6. Thats what the dealer uses and what GM recommends.
    Jan 2014
    USA
    04 ZHP, 83 320i, 00 M5
    Quote Originally Posted by dhurley34 View Post
    Thanks I was curious of what to use in the autos. My brother in law has an e39 525i auto.
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by Eaglesail View Post
    Scare tactics are not useful or helpful here.
    That is not an excessive amount of mileage,
    and a change to new fluid vs running old depleted fluid is an improvement, and ALWAYS a plus+ in my opinion.
    Wadsworth, Ohio
    BMW
    Perfect time to change it, RedLine D4 ATF is what we recommend and use in our service kits (LINK).
    -James
    Dec 2013
    Chicagoland area
    EXOTICS
    Agree, RedLine is an excellent upgrade fluid!
  1. e36 M3 AUTO Trans Service Questions
    By maddog4079 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-27-2012, 09:19 AM
  2. Auto Trans service / flush
    By tbsbimmer in forum 1976 - 1989 (E24)
    Last Post: 06-01-2011, 11:57 PM
  3. What is the BMW auto trans service?
    By 5XXi in forum 1996 - 2003 (E39)
    Last Post: 07-09-2010, 06:15 PM
  4. e34 535i Auto Trans Service
    By whiteride in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-06-2010, 08:11 PM
  5. 1990 325i auto trans service procedure
    By Rusty Strummer in forum 1983 - 1991 (E30)
    Last Post: 03-13-2010, 07:32 PM
