Results 1 to 15 of 15
Thread: Brake Accumulator
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Brake Accumulator
    I need confirmation that my symptoms are brake bomb related.
    1. I get a recurring noise from the engine bay near the pentosin reservoir every 7 seconds when stepping on brake. I checked to make sure no air in the system by checking for bubbles in the reservoir when pumping the brake.
    2. Brake is soft but no issues with stopping.
    3. I know I am missing one of the rubber seals that sandwich the filter (the top one)...not sure if that could cause the repetitive sounds.
    4. Groaning when turning steering wheel.
    Thanks in advance for ur advice.
    Sunny Cali,
    6.5 second 69 Camaro
    When you slam on the brakes and it stops today, The Accumulator is fine! It will be stiff hard stopping with a delay when it go's south from my experience, If the pentosin level and filter is ok, There is a post on adding a small cut in the top of the reservoir to relieve some air pressure and the winding noise has left in several cases.
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Too low pentosin level?!
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Quote Originally Posted by 8eights View Post
    I read the post suggesting notching to allow air in but my symptoms are different than what they were describing. I'll review again tho.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Quote Originally Posted by peake View Post
    Naw, that was the first thing I thought too.
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    My brakes were soft but braked like you described although the ABS never activated. The reason was I had never ever changed brake fluid. Not too much air in the system but water in the fluid. After changing ABS worked and brakes were stiff/hard and did their job much better.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    My brakes were soft but braked like you described although the ABS never activated. The reason was I had never ever changed braked fluid. Not too much air in the system but water in the fluid. After changing ABS worked and brakes were stiff/hard and did their job much better.
    That'll be good to do regardless but don't think that would address the rhythmic Brrrt noise every 7 seconds. Anyone else have any thoughts on this?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Could the noise be the pre-charge pump running? Removing the relay would test this (and probably be rather dangerous) - K94:
    http://www.meeknet.co.uk/e31/Timms_B...lay_Finder.htm
    My BMW Repair YouTube Channel
    Jun 2015
    West Chester, PA
    BMWs:74 3.0 CS, 97 840Ci
    If the booster 'bomb' is original, it is - at a minimum - 20 years old!! That rubber diaphragm does not last forever. Mercedes has used these accumulators for self leveling and to augment the hydraulic suspension in cars for quite a long time. Ten to fifteen years is considered a reasonable lifetime in that community. I always replaced mine at around 12-15 years on the Benzes.
    I replaced this pressure accumulator on the e31 a few weeks ago. I've noticed improved braking and less hydraulic fluid/pump noise. Working slowly (on a lift), probably took about 2 hours for the job.
    Gary
    Gary Knox
    '97 BMW 840 Ci
    '03 MB SL55 AMG
    '07 Mini Cooper S hatchback
    '09 Aston Martin DB9 Volante
    '13 Audi A8
    '90 MB 560 SEC and '94 Porsche 928 GTS recently departed but long enjoyed
    50 or so others over the past 70 years of driving
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Could the noise be the pre-charge pump running? Removing the relay would test this (and probably be rather dangerous) - K49:
    Thanks Timm, did you maybe mean K19...I don't see 49 on your diagram? Thanks.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Quote Originally Posted by Gary Knox View Post
    Gary
    I hear ya Gary. Im all for preventative measures and will likely do this soon regardless.
    Thanks.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    No, I meant K94.....
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    The K94 is present in the 840 but is it also present the the older 850?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    If you have slip control 5 then you have K94 - otherwise the relay is part of the hydraulic unit Y1
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    will give it a go when it warms up. Hard to motivate with sub freezing temps! Thanks.
  1. Removing and Replacing the Brake Accumulator
    By Sansouci in forum 1976 - 1989 (E24)
    Last Post: 12-03-2013, 10:41 PM
  2. How to replace brake accumulator on early E32
    By bkatz in forum 1988 - 1994 (E32)
    Last Post: 12-24-2010, 12:21 AM
  3. Brake accumulator replacement
    By smiller in forum 1976 - 1989 (E24)
    Last Post: 05-24-2008, 05:20 PM
  4. Was I sold the wrong part? "Brake accumulator"
    By PaperBoy in forum 8 Series (E31)
    Last Post: 04-13-2008, 01:45 PM
  5. E28 533i: replacing brake accumulator
    By MatthewakaMatt in forum 1982 - 1988 (E28)
    Last Post: 09-01-2006, 03:14 AM
