From what i understand, the rear outer lower control arm bushing can be replaced with a ball joint which is the same as the upper rear outer.
Can anyone confirm that part # 33306852895 can be used for the upper and the lower.
Correct, it can. This is the factory setup on the M3 cars.
1997 328i/4/5 - Cosmosschwarz Metallic on Dove Grey - Auto/Manual Swap - M3 Bilstein Sport/H&R Sports (95 M3 mounts) - Offset M3 LCAB - 20mm M3 rear sway bar - X-Brace - AA Tuning Strut Tower Bar - Rogue Engineering RSM - Dinan Cat-Back - 3.38 LSD - E46 330 front/328 rear brakes - SS Brake Lines - E36 fitment Style 42's (staggered) - M3 Front Bumper - M3 side moldings - M3 Rear Diffuser - DJ Auto Headlights (6k HIDS) - Frenched Fogs - OEM Clear Tails - E65 Rearview Mirror (Homelink controls + Autodim) - Alpine Type S Cabin Speakers (6x9 Retrofit) - 8" JVC woofer - Black Kidneys - Red Needles/Chrome Gauge Rings - OEM Alarm - Full Interior/Trunk LED Lighting - Mishimoto Full-Aluminum Radiator - More to Come!
Yes it can, and that is what i did when I replaced the rear bushings on my 328i. Just order 4 ball joints and you are good to go.
Mike
1999 750 IL (SOLD)
1990 750 IL (SOLD)
1989 325IC (SOLD)
1995 540I (SOLD)
1999 323 (SOLD)
1998 328I 195,000 miles and counting
2017 Ford Expedition Platinum
2016 Lexus RX350 F-Sport
They are also very easy to replace. Can be done on the car. Just have to take off the Brake Caliper Bracket / Assembly.
