Results 1 to 15 of 15
Thread: 2008 E92 M3 DCT Racecar
    Phoenix, AZ
    2004 E46 Dinan S2 M3
    For Sale: 2008 E92 M3 DCT racecar, ready to race in NASA GTS-3, GTS-4, or CCA B-Mod, Built for reliability and easy maintenance.
    Chassis: 2008 Space Gray E92 M3, fully gutted, lightened, AMAZING roll cage built by Eric Langbein Racing. Turner Solid rear subframe mounts, solid diff mounts, engine mounts, trans mounts. Wiring harness thinned/deleted where possible. About 2990 lb with no driver at 5/8 full tank.
    Drivetrain: S65 with about 34k miles, Macht Schnell intake, Secondary air delete, ESS Custom tune (have Epic tunes for both GTS-3 and GTS-4), Macht Schnell primary cat deletes to custom exhaust with Borla Mufflers (quieter than 103 db at Sonoma), 7-speed DCT transmission (ZERO issues with DCT on the track, it's awesome), Diffsonline race diff with Bimmerworld custom rams, and 3.63 gear set. Rod bearings replace at 32k with stock WPC coated bearings and new ARP Rod Bolts. Custom AC Delete with Dinan Power Pulley.
    Suspension: MCS double adjustable remote reservoir coil overs front and rear with 2.25 springs (1000 lb fronts and 900 lb rears), helper springs with guides, Torrington bearings, rear clevis mounts, Ground Control Camber/Caster Race plates, RD Sport hollow sway bar front and rear, Bimmerworld Precision front lower control arm bearing kit, Dinan Rear Toe Link Set and custom made adjustable front sway bar end links.
    Brakes: GRAND AM/IMSA Brembo 4 Piston Front Kit with 25mm thick pads ($6,775 retail) and stock rear brakes with Cobalt Friction Pads. New stainless lines and Bimmerworld carbon backing plates/ducts
    Body/Aero: Bimmerworld Carbon headlight delete, custom carbon race wing bolted directly to chassis with cut outs in Fiberglass rear trunk for extra weight savings. Challenge USA Front Splitter with built in air ducts, Bimerwolrd carbon wiskers. Front hood and rear trunk have air catch latches and terry body springs in rear.
    Safety/interior: SPA mechanical fire system (1 year left for Re-cert), Allview wide angle mirror, Wired for Coolshirt Club System, Schroth Profi II Hans harness (Expires at end of 17), Sparco Pro ADV halo seat with Sparco and Macht Schnell mounts (expired seat with seat back brace so its good for 5 more years), G-Force Mesh Window net and Schroth Right Side Window Net. Motec C125 Dash connected via CAN High and Can Low for easy to use logging. Also, two endurance lights installed on hood for use at night. Easily removable.
    3 sets of wheels: 2 sets of Apex ARC-8 18x10 square setup wheels in black with 1 set of 1 heat Cycled Yokohama Race Slicks. 1 set of Apex EC7 18x10 square set up with 1 heat cycled Nitto NT01s.
    Car is located in San Jose, CA. $71,000 with some spares, ready to race. Contact Alex at 619-778-1930
    https://drive.google.com/open?id=1VF...insXJVPXuqOF1-
    Phoenix, AZ
    Bump for xmas. Would make for a great xmas present
    Phoenix, AZ
    2018 Bump
    Phoenix, AZ
    Price drop to $73,000
    Phoenix, AZ
    Price Drop to $71,000!! Willing to listen to REASONABLE OFFERS
    Phoenix, AZ
    Bump to top.
    Phoenix, AZ
    $68,000!!!!
    Phoenix, AZ
    $64,000!! Ttt
    Phoenix, AZ
    Still for sale
    Jul 2006
    Fast Lane
    e24 M6 / e36 M3
    link does not work for photos
    Phoenix, AZ
    Quote Originally Posted by Bm6w View Post
    Dec 2015
    westchester
    2011 E92 m3
    Such a perfect build! I spoke to Alex and this car is built exactly to the specs (Perfect) i would build my E92 M3 that is currently for sale.
    Phoenix, AZ
    Car is still for sale. Looking for a new home this winter!!!
    Phoenix, AZ
    New year and ready for a new home!!!
    Phoenix, AZ
    Willing to make a deal!!!!
  1. E9x FS 2008 E92 M3 Sparkling Graphite/Black DCT 71K - North FL
    By w0ady in forum 3 series & Z Series
    Last Post: 01-08-2016, 05:51 PM
  2. Wts: 2008 e92 m3 dct
    By Mark540i in forum Hawaii & Other Islands
    Last Post: 11-29-2012, 10:07 PM
  3. 2008 E92 M3 DCT with less than 2000mi
    By xeler8 in forum 3 series & Z Series
    Last Post: 11-11-2008, 11:34 PM
  4. My friend is selling his New Red 2008 E92 M3 if anyone's interested
    By Ali in forum Georgia sponsored by Harrison Motorsports
    Last Post: 03-11-2008, 03:13 PM
  5. PS Request: e92 M3 Circuit racecar!
    By jkalex05 in forum BMW Rides & Events
    Last Post: 01-01-2008, 02:11 AM
