Results 1 to 3 of 3
Thread: Weird light issue
    Aug 2016
    Ajax,Ontario,Canada
    1993 BMW 318is
    Weird light issue
    My E36 has a weird problem with the headlights/tailights. My low beam headlights are always on (if the car is on) and turning the headlights on and off with the headlight switch doesn't do anything, my tailights don't even come on. I replaced the headlight switch but am still having the same issue. I was thinking maybe a fuse or the trunk wiring? Any help is appreciated.
    Jun 2010
    NY
    1997 328i
    Early E36's are known to have bad wiring in the trunk. Remove all the carpet/trim in the trunk and investigate. Bad wiring also goes into the trunk lid on the left side.
    You can replace bad wiring one at a time, there is also a replacement wire harness available somewhere.
    Oct 2003
    Seattle
    99 M3
    The trunk lid repair harness is p/n 61128391788
  1. Weird light issue
    By CC325i in forum 1991 - 1999 (E36)
    Last Post: 07-27-2012, 10:12 PM
  2. weird lighting issue
    By e30nate in forum 1988 - 1996 (E34)
    Last Post: 07-02-2011, 11:03 PM
  3. weird lighting issues.
    By Brewtech in forum 1976 - 1989 (E24)
    Last Post: 08-29-2008, 02:22 AM
  4. Weird climate control light issues
    By M pwrd in forum 1992 - 1999 M3 (E36)
    Last Post: 08-28-2006, 12:36 AM
  5. Weird (minor) dash lighting issue
    By GuinnessDraught in forum 1988 - 1996 (E34)
    Last Post: 08-21-2006, 09:11 PM
