Results 1 to 4 of 4
Thread: Front subframe bushings?
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    While browsing RealOEM for something possibly useful to E32 owners, I stumbled upon a parts catalog diagram of what appears to be a rubber-suspended crossmember, that the thrust arms bolt to. I can't for the life of me find a photo. Can anyone confirm if an E32 actually has this? Why are the bushings greyed out on the catalog page?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    That part # 2 was on the E32 only used a short time, Rubber Mounting up to 09/1987 31121130444 http://www.realoem.com/bmw/enUS/show...diagId=31_0147
    I once bought 2 for a friend who has a 1987 E32 Alpina B11, pics here http://alpinakozou.web.fc2.com/file/...20110103b.html
    https://www.ecstuning.com/b-genuine-...r/31121130444/
    Cross member 31121134050 valid
    Rubber Mounting 2pcs up to 09/1987 31121130444 only applies to Cross member up to 09/1987 31121130588 ENDED
    moroza's Avatar
    BFE
    E34T
    So post-9/87 E32 had a solid E34-style crossmember?
    Jan 2005
    Japan
  1. E36 OEM BMW (front) & Febi Bilstein (rear) e36 M3 Subframe bushings
    By Brent in forum Suspensions, Springs & Shocks
    Last Post: 02-14-2012, 12:38 PM
  2. E36 95 M3 Front subframe, hubs, control arms, lolipops with powerflex bushings
    By conway in forum Suspensions, Springs & Shocks
    Last Post: 09-15-2011, 02:14 AM
  3. 1990 750il Front subframe bushings
    By 85k100rt in forum 1988 - 1994 (E32)
    Last Post: 11-19-2009, 01:45 PM
  4. What is correct size for front and rear subframe bushings?
    By DSrugis in forum 1992 - 1999 M3 (E36)
    Last Post: 11-28-2008, 08:29 PM
  5. Are There Front Subframe Bushings?
    By zrozof in forum 1992 - 1999 M3 (E36)
    Last Post: 03-05-2006, 09:02 PM
