Im planning a 750 brake upgrade. If anyone has done this and rebuilt the calipers, where can i get a decently priced kit for the front and rear caliper rebuild?
I found this one for the front on ebay...
https://rover.ebay.com/rover/0/0/0?m...2F311876903127
Sent from my SM-N910T3 using Tapatalk
The UK one seems pretty good actually. I tried lookin up and down and most places don't offer the piston. For the seals and bushings it is a good buy.
Also... If you need some calipers let me know I have a F/R kit i ended up not using.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
Stuff For Sale :
All types of E39 OEM Used HVAC Buttons
Other E39 Parts, see my ebay! [Click]
IMO I would never rebuild a caliper. Too much potential for later failure. Rebuilt calipers are relatively cheap, either loaded (with pads) or unloaded (no pads) I would also replace the flex hoses to the calipers.
Some of the diesel E38s were equipped with Brembo brakes. Those would be awesome but sourcing rotors and pads for it might not be easy.
Like these?
https://rover.ebay.com/rover/0/0/0?m...2F173023360907
Yes, gorgeous aren’t they. I may go that route on the next brake job. Having them powder coated to red as well. Would look great on Alpine White.
I have a set of 750 fronts with brackets and pads if anyone is interested...
Did you rebuild your calipers and install them? What kind of rotors did you use?
Also, I need a new key..cheers
