Results 1 to 22 of 22
Thread: Post 7/02 e39 headlight success stories?
    Dec 2010
    Sterling, VA
    98 540i e39
    Hi,
    Currently vacationing in the Philippines and working on my fathers e39. Bought some EvoxR projectors to retrofit his headlamps. To my surprise, he currently has a face lifted assembly that is post 7/02 which I believe is permasealed and unbakeable.
    Unfortunately, finding parts here is not as easy even being used. I've been reading some posts on HIDnet and there have been some success opening a permasealed assembly. I also saw someone with an F30 that opened his with a heat gun and some prying tool.
    It seems doable, and in my case, appears to be no other option but to tackle the job... I just wanted to see if there's anyone here in the forum that was successful in opening the assembly without havin to cut and replace the lenses, and if you can share some tips and advice. Thanks!
    Sent from my SM-G955U using Tapatalk
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    I have not yet seen anyone successfully remove the unbakeable lenses without destroying them. There are some interesting hook shaped knife tools made for cutting the glue though.
    Dec 2010
    Sterling, VA
    98 540i e39
    Quote Originally Posted by philly98540 View Post
    The more i read, the more i think it is doable... but i have not come across anyone who specifically worked on a latter e39 headlight... hence, i amwith an hoping someone has actually done it on an e39
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    There's vendors who claim they can do it but won't divulge the method. IF they are glued with epoxy (which is what legend claims...) then epoxy can be degraded w/ heat but thats a crapload of heat for a plastic assembly, and usually requires some good force as well even after its been heated (unless you can really destroy it aka like acetylene torch hot). I think cutting has to be the method?
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Dec 2010
    Sterling, VA
    98 540i e39
    The sealing material appears to be silicone like, not a hard cured epoxy... i really dont have much option right now... if i cut it open, we dont have a lens to replace it with...
    Mar 2012
    Lansdale, Pa
    I think it's a cured urethane type caulk adhesive on the non bake able lights. Very tough and tenacious stuff but not solid like an epoxy.
    Mar 2010
    You know I think maybe I was comfruzing a similar Audi headlight that's epoxied?
    2003 M3CicM6 TiAg
    Former:
    Raleigh, NC
    SR-71 Blackbird
    Destroying the lens is a pretty pain in the butt and takes time and a lot of effort. Plus, it gets nasty.
    If somebody finds a way to disassemble the sealed lens without the need to destroy them thrn please share here.
    Dec 2010
    Sterling, VA
    98 540i e39
    Will be doing this tonight... wish me luck
    May 2016
    NYC
    2003 BMW 530i
    Take pictures. Will be likely doing this shortly
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I'd recommend replacing the lenses if that's at all an option for you. At these cars' age, the plastic lens is probably brittle and likely to crack, as well as covered in scratches and pitting from road miles.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Raleigh, NC
    SR-71 Blackbird
    Quote Originally Posted by computiNATEor View Post
    Well, yes, eventually the lens will get replaced. The issue is how to get the original untouched, unbakeable sealed lens off of the headlight assembly without cutting it out. If there's an easier method to get the lens off cleanly then that's what I and others are interested to know.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by auaq View Post
    Right, trouble is, the easy method is with a dremel. :/
    Nate J.
    Dec 2010
    Sterling, VA
    98 540i e39
    Have you guys seen the video of the one opening his F30 headlights? Those headlights are bonded with what they call a permaseal... maybe something similar to what the e39 uses...
    Raleigh, NC
    SR-71 Blackbird
    Quote Originally Posted by burakol View Post
    Post the link if you don't mind.
    Los Angeles, CA
    Formerly 03' 540i
    I think part of the reason behind not being able to open E39 03' spec lights is due to the housing plastic composition itself. More specifically they seem ALOT weaker structurally than newer models.
    I can easily break the channels holding the lens in. On top of that moving a tool in between the lens and channel is a serious challenge.
    2003 BMW 540i [Sterling Gray / Gray]
    [Msport] [Mods from A-Z] [Two-Tone Interior]
    Stuff For Sale :
    All types of E39 OEM Used HVAC Buttons
    Other E39 Parts, see my ebay! [Click]
    Dec 2010
    Sterling, VA
    98 540i e39
    https://youtu.be/LLSOEKl1t8U
    Dec 2010
    Sterling, VA
    98 540i e39
    Quote Originally Posted by Dking078 View Post
    Now I totally get what you are saying. The housing itself is prone to breaking... i think the key is heating ir on the backside before prying it open. Im wondering if i end up cutting the outer channel, would I still be able to seal the insides decently? In the situation I am facing right now, it is inevitable that i save the lenses... the asjusters are also broken so i really need to get it open...
    I know these a way to change the adjusters without opening it but I dont have a long torx screw to use...
    May 2016
    NYC
    2003 BMW 530i
    Are you able to find a set of halogen housings? If your ultimate plan is to replace the adjusters and the projectors, then find a pre 7/02 halogen housing for cheap(er) than xenon housings. This is what I did when I swapped in some hella g4 bixenon projectors.
    Dec 2010
    Sterling, VA
    98 540i e39
    Finding parts here in the Philippines is next to impossible... the current housing is a halogen and the plan was to drop in an EvoxR projector and HID.
    If I would have known that this housing were updated by my in-law, I would have sourced either an aftermarket or used before I left the states.
    The only set Ive found so far here is a preface assembly, which is actually the spec headlight for his car... either I buy that one and do the retro, plus install an AE since that is one of the things he likes...
    Apr 2015
    United States
    2003 540i6 M-Sport
    Just do the ship in a bottle technique to fix adjusters.
    Jul 2010
    Ontario, Canada
    2003 BMW 530i
    This any help deciding what to do & possible methods?
    http://www.m5board.com/vbulletin/e39...-lights-7.html
    Regards
    RDL
  1. Hella EvoX-R Bixenon Projector Retrofit into 2001/02 e39 Headlights DIY Guide
    By cwise12 in forum E39 Common Problems and DIY Fixes
    Last Post: 03-26-2024, 06:31 PM
  2. E39 FS: E39 Post Face Lift Hologen Headlights
    By bimmerboy530i in forum Exterior Lighting & Body Parts
    Last Post: 08-26-2013, 06:39 PM
  3. E39 E39 01 02 03 Headlights Hella OEM PAIR
    By cal45fan in forum Exterior Lighting & Body Parts
    Last Post: 06-12-2011, 09:43 PM
  4. Post your E39 SUCCESS stories here...mods, etc.
    By ViolinARC in forum 1996 - 2003 (E39)
    Last Post: 05-10-2009, 02:10 PM
