Results 1 to 16 of 16
Thread: o2 probe
    Apr 2017
    denmark
    bmw e87 118d and e10 02
    o2 probe
    I need help on what wire goes where? Bought a new o2 sensor with 4 wires 2 white, one black, one gray. The wires on the e30 m10 118i has different colors, which is to what?
    Cheers from Mike-Denamrk
    Estacada Oregon
    E30M3 X2 R100GS/PD R60/5
    Quote Originally Posted by mikebike7 View Post
    Whites will be the heater circuit ,Gray is usually O2 output and black reference ground. Do you have your ETM for wiring color references
    Sent from my SM-G360V using Tapatalk
    Angus
    88 E30M3 X2 (1 summer/1 racetrack)
    89 325IX (winter)
    92 R100GS/PD
    Apr 2017
    denmark
    Do you have your ETM for wiring color references????? I can take o photo of the o2 plug and wire colors if that can help me get the wire spliced.
    Estacada Oregon
    ETM=Electronic Troubleshooting Manual ,Google wedophones bmw manuals and find your model ,Download the PDF it will be your friend once you get comfortable using it.
    find the Fuel injection section and O2 diagram for wire colors to match your generic O2 wires to.
    Angus
    89 325IX (winter)
    92 R100GS/PD
    Apr 2017
    denmark
    Thank you for the help, i found the page and the colors, but i have 2 whites on the probe. I guess i can connect them together in one? Hope i am right. Please correct me if i am wrong. Cheers from Denmark
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    What wires are on your existing connector?
    "Howdy, Folks!"
    Apr 2017
    denmark
    There is a green, a blue/green and a brown
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Sounds like you have a 3 wire system. In this case
    green/blue - O2 heater power
    brown - O2 heater ground
    green - signal (circuit completes through engine ground)
    Your new one is
    white - heater (power or ground) -- map one to green/blue
    white
    - heater (power or ground) -- map the other to brown
    black - signal -- map to green
    gray - signal ground
    How to deal with the gray wire
    The old system grounds the signal through exhaust pipe to engine to chassis ground. A fourth wire was added to provide a more stable ground to the engine electronics. You can route that wire to any good chassis ground on the firewall. If you can tell me if you have a Jetronic, Motronic 1.0 or later Motronic 1.1/1.3 I could probably recommend a better location. However it might not be worth the extra work.
    "Howdy, Folks!"
    Apr 2017
    denmark
    Wow what a help, thank you very much. Cheers from a 2002tii owner.
    Apr 2017
    denmark
    Sorry forgot to write that the 2002 has a e30 188i m10 with motronic, where do i find what type motronic it is?
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    When you say an e30 M10, I'm assuming you mean a Euro market 318i. These were made through 7/87 production. That means it's likely only Motronic 1.0. Do you have a separate idle controller computer? Then it's definitely Motronic 1.0. Otherwise it's M1.1/1.3 that don't have much functional difference.
    Now with that said, are you sure it's not L-Jetronic? I wasn't aware the M10 ever got Motronic. I'm not familiar with Euro market cars to say with certainty. I thought the M40 with the distributor cap fixed at the front of the head got Motronic (spark and fuel control) while the M10 with a old style distributor got L-Jetronic (fuel only control).
    "Howdy, Folks!"
    Apr 2017
    denmark
    You are completely right, it is a l-jetronic, so guess i still have to follow the same wire connection you wrote.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    With an L-Jet system, run that ground wire to anywhere on the engine. That's where all the other injection components ground. The best place would be ground location G102. I don't specifically know where that is located other than the description in the ETM, "Top rear of engine." There should be a bunch of other wires already grounding there. There's also G101 which is described as "Top front of engine" and appears to be by the cold start valve. G101 only applies to "early production." "Late production" has everything ground to G102. Don't be surprised if you don't have G101. If you can figure out where G102 is, it's the best choice.
    "Howdy, Folks!"
    Apr 2017
    denmark
    Well have at last time to put the probe to the 2002. But the green/gray has inner and outer wiring, do i connect both to the black?
    Apr 2017
    denmark
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    I replied in your message, but for completeness...
    The inner wire is the signal wire. The outer wire is an RF shield. Since this is the old chassis side, the shield should already be tied to ground somewhere but you should verify,
    "Howdy, Folks!"
  1. o2 probe
    By mikebike7 in forum 1983 - 1991 (E30)
    Last Post: 11-28-2017, 11:08 AM
  2. Which o2 sensor is lambda probe 1?
    By e46tknv in forum 1992 - 1999 M3 (E36)
    Last Post: 07-14-2014, 06:26 PM
  3. Lazy O2 Sensor or Gremlins?
    By Kevlar in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2001, 06:00 PM
  4. O2 sensors for 325i. How many are there?
    By ///Arman in forum 1991 - 1999 (E36)
    Last Post: 03-07-2001, 05:56 PM
  5. O2 Sensor Questions
    By ///MCubed in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2001, 02:08 AM
