Results 1 to 4 of 4
Thread: wheel tire sizes
    Feb 2016
    Sandy, OR, USA
    2008 Bmw 535xi
    wheel tire sizes
    I have a 08 535xi and I know I can go staggered safely, but I'm just having a hard time deciding on width and offsets. If y'all would be so kind to help a brother out with info and pic's that'd be awesome! I'm going with 19's, preferred info with these but I'm open to other options if they catch my eye.
    Mar 2008
    Monroe, CT
    2007 530xi 6 spd.manual
    The important thing to remember with E60 AWD cars is that the rolling circumference has to match within 3% on all four wheels. Otherwise, you risk trashing your transfer case. A site like http://www.willtheyfit.com/ will help you determine this.
    Wheel offsets for xi's range from ET 35 to 45.
    Start with a site like tirerack.com to determine standard tire sizes for your model.
    2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
    Wadsworth, Ohio
    BMW
    It's easy enough to go square on the E60/E61 that I usually suggest that path over staggered, just to avoid having to play tire size games. But if you want to go staggered getting less than a 1% match in tire sizes is fairly easy with all the options around nowadays.
    On my wagon, I went 19x9 ET35.5 (ET48+12.5mm spacer) front and 19x9 ET18 rear with 255/40/19 tires all around, rear required a mild roll to avoid rubbing, the front is rub free. If I had to do it again, I'd go with about a 5mm less aggressive setup in the rear to avoid having to roll.
    With AWD E60s I usually push my guys towards square setups and I usually suggest 19x9 ET35 squared with a 10mm spacer in the rear IF you want a more aggressive rear stance.
    -James
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Seems like you are using oversized tires. Stock sport wagon is 245/40/18. If you keep 40 serie when going to 19 and stay the same it wider, you are increasing the diameter over stock. I am not surprised that caused rubbing.
  1. Wheel / Tire Size For Track
    By italcarguy in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 09-26-2003, 12:08 PM
  2. '98 M3... Wheel/Tire size questions
    By RenaissanceMan in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-17-2003, 05:24 PM
  3. another wheel-tire sizing question
    By XOC in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-15-2003, 04:36 PM
  4. Going to order new rims, need input wheel/tire size.
    By YaYo325 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-13-2003, 06:50 PM
  5. e36 wheel/tire sizing
    By clor0x in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-23-2003, 02:27 AM
