Results 1 to 21 of 21
Thread: Time sert... need some help
    Virginia
    97' m52 turbo
    Didn't want to ask but...
    My rear shock where it bolts to the control arm is completely stripped.
    I bought 12X.1.5 tap and attempted but 0 progress
    What size time sert would you guys recommend ?
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    Well you would need a timesert or helicoil for the bolts thread size. Thread insert taps are larger to accommodate the thread pitch of the insert you are using
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    If you have an m12x1.5 bolt you need a m12x1.5 insert. Don’t forget to get the correct drill size for the STI tap also
    Virginia
    97' m52 turbo
    So would a 12x1.5 thread sert be about a 1/2 in size?
    Can I go standard?
    Jan 2016
    Ca
    2001 525it
    You buy the heli coil or timesert kit it would either come with the correct drill bit or will tell you which size to buy. As far as standard size the shock mount will not know the difference
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Alternatively you could try again to rethread. Maybe use a rethreader. Or try again with a tap. You have to get the angle just right on that bolt — it does not always go in at first try. Another thought would be to drill and tap for a larger bolt assuming your lower shock bushing liner could be enlarged to match. A used trailing arm is also an option.
    Nov 2017
    Harrisburg PA
    E36 coupe
    https://www.belmetric.com/m12x15-c-2...it-p-1540.html
    is the complete time-sert kit. I use these daily at work in a variety of sizes
    Oct 2016
    San Leandro
    2008 535i, 2004 328i
    Sometimes a longer bolt will catch threads that aren't borked.
    Virginia
    97' m52 turbo
    Tried a longer bolt, didn't work.
    Fastenal local to me has a thread insert kit with 12mm X 1.75. Thinking it should work the correct threaded bolt
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Have you already refreshed your rear suspension bushings?
    Virginia
    97' m52 turbo
    No
    Virginia
    97' m52 turbo
    Could I just drill through and put a nut on the other end ?
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by 328iFun View Post
    They are both going to have to same major diameter so no that won't work.
    If you drill it through you could just tap it deeper.
    Virginia
    97' m52 turbo
    Thanks for the help everyone.
    I went to fastenal and bought a 12mm bolt/nut and bit to drill it out so I could put a nut on the other end of the arm. The bolt I bought had a courser thread pitch and it ended up tightening very well with no drilling or modification.
    Boosted all evening, feels great. Rear needs re-freshened desperately though
    milKt's Avatar
    That's where I was headed with it.
    If the arm is damaged, there's no better time to replace the arm,
    swap all fresh ball joints/ bushing/ etc into each.
    You're fix sounds OK though.
    The shock won't go anywhere, with a proper 10.9 GRADE bolt
    also, you are 328, correct?
    Virginia
    97' m52 turbo
    Yes, the car is 328.
    It runs and drives fine (knock on wood). It just doesn't like to be beat on from a standstill but if the car is moving it seems to be fine.
    I'm going to to do the rear as soon as I have some extra money.
    The Konis feel great and the car handles good. Regretting going with the 5 series offset style 32's. Rubbing annoys the hell out of me
    Oct 2003
    Seattle
    99 M3
    Hard to believe you stripped the full depth of the lower shock attach bolt
    07119900402
    M12/1,5X60
    Is there enough material remaining to install a Timesert?
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by bluptgm3 View Post
    If he did no drilling of any kind, there's definitely enough to do a TimeSert.
    Virginia
    97' m52 turbo
    I think it may have had issues when I bought the car. And the impact just made it worse.
    I was able to make it work with a bolt with courser thread. Holding up fine. Will be good until I redo the entire rear
    Virginia
    97' m52 turbo
    Nov 2017
    Harrisburg PA
    E36 coupe
    Time-Sert makes oversized inserts as well.
    So if it is oblonged or oversized you can still use an insert and get back to the original thread size/pitch
  1. Need some help with the upper timing cover gaskets
    By SBK740 in forum 1995 - 2001 (E38)
    Last Post: 02-05-2015, 04:11 PM
  2. First time buyer, needing some help.
    By AstroPuls3 in forum Pacific Northwest - US
    Last Post: 08-20-2012, 10:04 PM
  3. Been a long time...need some help
    By RedExX5 in forum 1996 - 2003 (E39)
    Last Post: 12-28-2009, 11:19 PM
  4. Modification time, Need some help/advice
    By AzN_M5 in forum 1988 - 1996 (E34)
    Last Post: 12-21-2002, 02:54 PM
