Results 1 to 7 of 7
Thread: FS/FOR SALE CA NORCAL: 1984 733i manual swapped
    May 2014
    California
    84 733, 90 535i
    Hello all
    I have a 1984 733i that would not crank even if full battery. Everything worked including sunroof before went sitting for a few months. I have no time for projects due to long hours per day away from home and a ton of bills plus unforeseen expenditures screwing my finances at the moment(near future). I preferably would like the whole car gone as a whole, hopefully the already manual swapped helps with that
    Clean title, 165xxx miles. odometer is broken, probably around 168xxx or less I barely got any driving time off of it before it became non-op (problem listed above.) Silver paint is oxidized and has very minimal surface rust (If you want to see REAL rust take a look at my current one.)
    Battery relocated to trunk by previous owner, has holes routed for air bags, mild wire tuck, ac/heater delete, and a fully functional manual 5 speed swapped. Console and font is clean. Has had a custom dual pipe exhaust to a dual inlet/outlet tipped magnaflow muffler cat back.
    Previous owner known as negativecamber on here and stancenation. Can follow his threads for the manual swap and etc.
    custom dual pipe exhaust to a dual inlet/outlet tipped magnaflow muffler.
    My original intent was to drive this one while getting my current e23 in a more operable condition plus swapping parts in between. It currently has a usdm front end ziptied on with the metal bumper off.
    I will be taking off the euro rear bumper/side moldings indefinitely; the manual front seats, rear left window regulator, sunroof regulator, and rear right interior door handle are things I may take off as well. If I take these manual seats you may end up having electric seats static at how I have them situated when they're to be removed from my current e23 unless I figure out that it's easy to swap the whole console/electrics over.
    1200$ OBO (manual swap alone would cost this or more if you had to source/pay)
    ASFIK: Once it's up and going it'll just need regular fluid upkeeps.
    Thanks for viewing
    Pictures will be asap.
    Dec 2005
    Omaha NE
    84' 533i Turbo
    Is it Bronzit? Which gearbox does this have? Pictures would help with the sale.
    Mar 2013
    USA
    E21/early e23/e34
    Think it's Eric's- Silver if not mistaken, was on air suspension?
    May 2014
    California
    84 733, 90 535i
    Silver and was on air as mentioned with holes routing for lines. It's got a G260/5 from another manual 733i, as far as I know it's got a clutch kit/flywheel plus all needed changes to make it work 100%. Shifter has aluminium bushings.
    Not home, can get/pull pictures from a drive later.
    edit: Pictures would have to be at least tomorrow. Pitch black outside by 5 nowadays.
    Better pictures tomorrow.
    May 2014
    California
    84 733, 90 535i
    Personal steering wheel 500$ OBO SUPER FLEXIBLE no idea what these are really going for but if had to buy new it's over 650$ USD
    May 2014
    California
    84 733, 90 535i
    Rear left carpet peeled up due to leak found; no rust/rust rot found in the vicinity. Always soaked dry when needed.
    May 2014
    California
    84 733, 90 535i
    bump
  1. Replies: 5
    Last Post: 01-06-2016, 08:58 PM
  2. 535i manual for sale in Norcal needs work
    By arch4ngel in forum E34 Classifieds (closing soon)
    Last Post: 05-27-2014, 09:29 PM
  3. Clean 2004 525i Manual for sale CA
    By tjackson9810 in forum 5 series & 6 series
    Last Post: 05-22-2012, 08:57 PM
  4. Cars for sale in NorCal bayarea
    By MCorpse in forum BMW Parts For Sale
    Last Post: 02-03-2003, 03:47 PM
  5. FS - FOR SALE *Canon S330*
    By ThreeCIRide in forum BMW Parts For Sale
    Last Post: 05-27-2002, 01:07 PM
