Results 1 to 8 of 8
Thread: Disintegrated Bump Stops
    Jul 2012
    South Yarmouth MA
    11/87 735i & 735il P/C
    While replacing the rubber brake lines in the front of my 735i, I couldn't help but notice that the dust boots and bump stops on both shocks have completely disintegrated into little tiny pieces
    What are my options?
    Is this a dead giveaway that the shocks/springs are toast? Car has been sitting for ~5 years, but only has 44k miles.
    I'm thinking a temporary fix could be cutting some new bump stops down the middle and then securing them around the shock shafts with large zip ties or hose clamps. I'm just not sure how much it compresses when going over large bumps and if the zip ties/hose clamps would be quickly destroyed.
    1983 4-spd Mercedes 240d w/403k - Sold!
    11/87 E32 735iA w/45k - Daily Driver (finally!)
    04/88 E32 735iL - Parts Car
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    That is normal after so many years that the bump stops and the dust boots disintegrate.
    I have replaced them on front and rear, but for that you have to remove the shocks, you need a spring compressor for that. http://www.nmia.com/~dgnrg/page_27.htm
    Might be possible to do a temporary fix as per your idea.
    Jul 2012
    South Yarmouth MA
    I've heard shocks should be replaced after 10 years, regardless of miles traveled. Have you found that to be the case with the e32 7's?
    I'm trying to budget the restoration, and I'd hate to needlessly spend $ if the shocks on my car are fine with only 44k miles. Might have to wait until I get it mobile to make that call though...
    Jan 2005
    Japan
    Probably depends on mileage and road conditions, not years. My 750iL now has about 175000 km and was built 11/1988, still original shocks installed, I only replaced the rubber/plastic parts like dust boots and bump stops.
    But of course I have no real comparison with new shocks, maybe the drive feeling is different then.
    Albuquerque, NM
    way too many
    I did a couple token FEA simulations for a regular bump stop vs. one with a slit in it. The boundary conditions and loads are a wag but the slit doesn't appear to make a significant difference. I say go for it with zip ties vs. removing the strut to insert a new one.
    You can go back and check on it say 100 miles later to see if the ties are intact.
    ​"The US Olympics bobsled team has renamed their sled 'Biden' because nothing has taken America downhill faster"
    TheStigg (aka "gale")
    92 735i 5-spd, turbo pending
    89 535i 5-spd (may she rest in pieces)
    94 325ic 5-spd
    87 325is
    Jul 2012
    South Yarmouth MA
    Quote Originally Posted by TheStigg View Post
    Thank you for taking the time to run those simulations!
    I say go for it with zip ties vs. removing the strut to insert a new one. You can go back and check on it say 100 miles later to see if the ties are intact.
    I think I will end up going with that option for now. Hopefully it's not a waste of a good set of stops, but I think it's worthwhile to test it out.
    I'm guessing it's a big no-no to drive without bump stops at all...
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    I may do this too! Mine disintegrated as well, been driving the car without them but I dont think it would be detrimental to do so right? I assume this is only used in cases where shock travel reaches near limit?
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
    Jul 2012
    South Yarmouth MA
    Quote Originally Posted by SergeBMW View Post
    I'm no expert, but my gut tells me this could accelerate deterioration of the strut if it's being slammed down to it's most-compressed state and hitting metal on metal at the strut tower (vs. hitting rubber with the bump stop installed)
  1. bump stop question
    By Saul in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-16-2002, 12:46 PM
  2. Bump stop question
    By BlackTintz in forum 1991 - 1999 (E36)
    Last Post: 07-16-2002, 01:12 AM
  3. Bump Stop Missing from GC Rear Shock!
    By ///M3 2 NV in forum 1992 - 1999 M3 (E36)
    Last Post: 07-13-2002, 06:43 PM
  4. Bump stop question.
    By aus in forum 1992 - 1999 M3 (E36)
    Last Post: 06-03-2002, 11:18 PM
  5. What to do w/ bump stops w/ bilstein sport & H&R sport??? HELP!!!
    By ///MForever in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-17-2001, 07:40 AM
