Results 1 to 13 of 13
Thread: Rear washer fluid works but not front
    Nov 2017
    Austin, TX
    2001 540i, 2002 540iT
    Hey all, new to the forum after picking up a '99 540iT. I noticed that the washer fluid works for the rear without any issue but not at all for the front. I tried refilling the reservoir thinking it may be low but didn't make a difference. Does the touring have separate pumps for front and rear?
    Car is currently at the shop getting the CV done. Want to know if this is something I can tackle or something I should have my indy guy do whi,e he is working on the car anyhow. I had a similar probably on my A8L but that was because a mechanic forgot to reattach a line and it was buried in the bumper.
    Thanks in advance.
    Los Gatos CA
    1987 325is, e34, Z3, e39
    The e39 has up to four washer pumps.
    One is on the intensive fluid reservoir that is visible in the engine compartment. The other two or three are on the main washer fluid reservoir hidden behind the right wheel well liner.
    There are separate pumps for the front windshield, rear window, and headlights (if equipped).
    Two fluid lines (one regular, one intensive) run from the pumps to the windshield nozzles. Each nozzle assembly has two inlets, each inlet with its own internal check valve.
    It's common for the windshield hoses to become brittle directly above the exhaust manifold from the heat, while the protected ends remain flexible. It's easily replaced by 1/4" black poly irrigation tubing. Heat the hose ends in near-boiling water remove and replace.
    It's also common for the headlight washer tubing to become brittle. It might be from the headlight/foglight heat, but it's less clear that's the source of the problem. It's 10mm ID, 1mm wall thickness. White 3/8" poly tubing isn't an exact match, but will work as a replacement.
    Nov 2017
    Austin, TX
    Quote Originally Posted by djb2 View Post
    Thanks djb2.
    I have ordered a couple of sets of tubing and will give those a go as an initial step to see if that solves the problem. Will tackle that when I get the car back this weekend.
    Sep 2014
    KS
    e24e30e36e39e90
    It's probably the pump. Do you hear the pump run when you pull the stalk? If not, it's the pump. I have had to replace both of mine, front and rear. The pumps are cheap, I recommend ordering two and replacing both at the same time.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Great post as usual, only one thing to add.
    Those pumps can and will go bad. Good news is they are SUPER standardized... I have 4 in my E39 and 2 in my E46 so I always keep a spare on the shelf. Easy fix. They also have little filters in the grommets that hold them, the grommets can start to harden and leak with age, and 'disturbing the force' by pulling one for the first time in almost 20 years sometimes incites the leak, so, might consider getting a new one of those if you swap the pump. Because the pumps are standard also you can do a quick swapperoo of the connectors to confirm that the pump is dead doornails BTW.
    Quote Originally Posted by sienayr View Post
    Oops sorta said same thing... read ahead, GG...
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Mar 2010
    The generic Continental / VDO / Siemens for < $20 works great BTW. I see there's a Febi that's under $10 too... I go w/ the Conti/VDO's myself.
    2003 M3CicM6 TiAg
    Former:
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    +1
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Los Gatos CA
    Three of the pumps are the generic type, with a hose barb for the fluid connection.
    If you have the headlight cleaning system, that fourth pump is part 67-12-8-377-430. The only obvious difference is that it has a large quick connect instead of a hose barb. More subtly the electrical connector is keyed differently. There must be something else that motivates a unique part.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    On the h/L washers it is volume vs pressure difference. Big fat hose with a big pump to drive the fluid. Worse BMW idea yet for nice cars as it dumps 100cc out each nozzle out on to the front end and hood on any hot hot day. Besides those who drive in the Rust Belt. Anyone else ever want it to turn on? I pulled the electrical connector on mine at the pump to resolve it ever cycling on. It was one of those items that should be deleted at ordering time many years ago.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Los Gatos CA
    Ahh, that makes sense. I tried to measure the current draw of my spare running dry, and it sounded as if would blow up at 6V / 2A. I then tried to run it wet with no backpressure, and the current went up dramatically limiting my test to 4V. I'll have to get my system sealed properly so that I can test the current draw on the installed system.
    The reason I have a spare is that the original pump wasn't running. When I went to replace it, I found that the pump itself was fine. I wonder if an earlier owner cut a wire or pulled a fuse to keep it from wasting fluid.
    Mar 2010
    Quote Originally Posted by StephenVA View Post
    Yeah but for some of us in the Snow / Salt Belt, it gets tedious receiving lectures and rants again and again from d-bags in AZ or FL or TX who insist the system has absolutely zero use to anyone ever and is completely stupid and never does anything (not saying that's you, just sayin' I bin through that topic from ranting whacko nozzle-haters even more times than "how does this M sticker look on my plain not-at-all-an-M car" threads).
    It is REALLY good for those few times you need it in-season if you live in the place where you need that sort of thing.
    What I will grant for sure is, I don't like the lack of control of it on/off... the fact that always if your lights are on and you double-spritz your window, it comes on? Yes, annoying. Seems to be a sorta German / Euro standard tho, the Audis work the same way. But Id rather have either a dedicated button for it, or a way to turn off the activation so those times when you just want a second window spritz, you don't get the light blasters. Wonder if there's some coding options regarding how it activates? Maybe I'll look into that.
    2003 M3CicM6 TiAg
    Former:
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Driving in salt spray and ice build up is exactly why the system was designed. Those up in the frozen north need it functional on any daily driver. Here in the mid Atlantic we should have it working too as it is 25degrees and my street looks like Maine!
    good luck everyone and drive safe, fast , but safe.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
  1. '03 x5 rear washer fluid will not stop running
    By Loztsowlz in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-18-2016, 09:27 PM
  2. Replies: 7
    Last Post: 03-20-2013, 02:02 PM
  3. My Car washer fluid motor is not working
    By abilashreddy1 in forum 1999 - 2006 (E46)
    Last Post: 06-06-2006, 10:14 PM
  4. Rear Shock Mount cracked, but not all the way..
    By Jesse325i in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2004, 07:14 PM
  5. weird pic request: clears in back but not front?
    By indicaM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-27-2004, 03:20 AM
