Results 1 to 8 of 8
Thread: Heater doesn't work? Heat coming from the manual shifter area
    Jul 2015
    Portland , Oregon
    2x 850i auto / manual
    Question Heater doesn't work? Heat coming from the manual shifter area
    First off , I hate the searching function on this forum , looked up Posts in E31 forums with titles - Heater doesn't work - no results ? That's impossible . Am I doing something wrong or is the search function just weird ?
    Anyways , heater doesn't work and it's been iffy for a while and it finally stopped . It worked before after a long while of the car running , now it won't at all . Sword has been repaired . The odd part is I feel a lot of heat coming from where the manual stick shift is , but none from the defrosters on the windshield or the air vents . Any ideas why ? Thanks guys
    Car 1992 850i , manual
    Orange County, CA
    840Ci|725tds|Alpina B7
    Quote Originally Posted by TheShark850 View Post
    That heat is probably just coming from under the car through the opening in the body for the gear shift. I would check operation of the heater vent valve up near the firewall, which is in charge of the distribution (and blocking) of coolant the the dash/heater core.
    Jul 2015
    Portland , Oregon
    Is the heater vent valve inside the car or in the engine bay ?
    Jun 2012
    Mundelein, IL
    840Ci/6 528iT Europa TCS
    Engine bay
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    If you get lots of air and no heat - then this is the way to go:
    http://www.meeknet.co.uk/e31/E31_Hea...eplacement.htm
    http://www.meeknet.co.uk/e31/E31_Coo...g_Bleeding.htm
    If you get no air, hot or cold, then it could well be the blower motor itself.....
    My BMW Repair YouTube Channel
    Jul 2015
    Portland , Oregon
    Antifreeze , radiator and thermostat were all replaced , the heater worked afterwards (car had to run forever for it to turn on but it did turn on) . Now it just blows cold air no matter how long the car runs . I will definitely check into the things you mentioned . Your website is getting pretty nice and very well written , good job Timm
    Pittsburgh PA
    94 840ci
    Timm comes through again.
    I haven’t driven my 8 during winter for about six years. I took it out last week and the heater was just blowing cold air. So today I visited Timm’s site and followed his 4000 rpm bleeding directions. After about 20 seconds the air starting getting warmer and lo and behold I have heat now.
    Thanks Timm. It cost me about thirty minutes and zero dollars. Never would have thought the fix would be that easy!
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Either heater valves are sot or aux water pump seized or both.
  1. Heat coming from the vents under seats!
    By MIK1989 in forum 1995 - 2001 (E38)
    Last Post: 06-28-2012, 06:35 PM
  2. Heat coming from the dash board :(
    By fahdyehia628 in forum 1991 - 1999 (E36)
    Last Post: 07-02-2011, 04:59 AM
  3. Sound coming from the control panel area
    By Termi in forum 1988 - 1996 (E34)
    Last Post: 12-09-2010, 07:39 AM
  4. Replies: 24
    Last Post: 02-23-2009, 06:33 AM
  5. Heat comes from the driver side foot-well ALL THE TIME!
    By borntobonz in forum 1992 - 1999 M3 (E36)
    Last Post: 07-05-2007, 06:27 PM
