Page 4 of 6 FirstFirst 123456 LastLast
Results 76 to 100 of 140
Thread: Let The M73 Swap Begin!
  1. #76
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Quote Originally Posted by adwebinc View Post
    Awesome. Well. Took your advice last night and started tearing in. Long story short, engine hoist I bought was missing critical parts... super frustrating. So don’t have it on the stand yet. Started tearing into top end.
    Most of the calves were pretty clean, but some carbon build up on a few. Recommendations for cleaning up with heads still on?
    I need to take better pics of the cams as this angle is bad. But heads look pretty clean. Cams look good. No visible scoring or unusual wear. The oil spray bar on these heads is certainly way better than the M70!
    Did some additional research on the exhaust down pipes for the M73. It does NOT look as though the later E31 M73 downpipes will match up to the ‘91 stock exhaust. So, will still need to address that piece.
    Under the valve covers looks nice and clean! The oily grime in the intakes seems pretty normal in my limited experience (2 x M70's).
  2. #77
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by CDO5OO1A View Post
    Should look like this. (see pic).
    Attachment 619259
    Cams and roller followers look good though.
    Attachment 619260
    It happens... When pcv valves go bad oil gets sucked into the intakes
  3. #78
    Jul 2014
    Westfield, IN
    '91 e31 M70
    Since I’m going to swap the whole M73, I will just replace the 2 PCV valves. Will be good PM any way.
    Finally made some progress. Had to buy a whole new engine hoist. But got it together and got her mounted on the engine stand.
    It’s been slow going as I started a new job, Holidays... blah blah blah.
    I’ve tried to find the CRC gasket cleaner a couple of places including my local O’Reillys with no luck. I’ll just have to order online.
    Any value to painting the exhaust manifolds with ceramic exhaust paint?
    '07 e65|N62 - Alpina B7 - Black Sapphire|Black|Loaded|GONE
    '02 e46|M54 - Orient Blue|Beige|'Vert|GONE
    '00 e39|M52 - Anthrazit Metallic|Grey|GONE
    '01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line|GONE
    '91 e31|M70 - Schwarz|Schwarz|M70|FOR SALE
    '13 328i Auto - Black Sapphire|Coral Red|Sport Line|GONE
    '05 545i SMG - Jet Black|Black|Bamboo Anthracite|GONE
    '07 335i Auto - Montego Blue|Grey|GONE
    '05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|GONE
    '97 528i Auto - GONE
  4. #79
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    You will use M70 valve cover gaskets so just replace M70 pcv valves under the throttles.
    Amazon has the crc gasket remover with prime.
    No do not paint the manifolds, they flake, stink and peal.
  5. #80
    Jul 2014
    Westfield, IN
    '91 e31 M70
    Quote Originally Posted by dragon850 View Post
    Perfect. The PCV valves on my M70 powder coated VCs have less than 500 miles on them!
    Yup, already have some in my amazon cart.
  6. #81
    Mar 2016
    Tyler, TX
    1992 E31 850i
    I'm not sure there is any "value," but it certainly looks nicer. Dragon's point is a good one, though -- use quality material that isn't just going to burn off. If memory serves, I painted mine in high-temperature silver ceramic on the twin-turbo engine. (I know I did the intakes, valve covers, etc., and in my mind I think I did the exhaust as well.) I'll check next time I find myself out in that shop.
    I'm enjoying following this thread!
    Cheers, John
  7. #82
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Pulled the bottom pans and getting ready to swap the oil pumps.
    Sent from my SM-G925T using Tapatalk
  8. #83
    Jul 2017
    San Francisco
    540i
    Have to swap to m73 DME, right?
  9. #84
    The OC, CA
    95 840Ci
    Now that's significant HP gains!
    Current
    95 e31 840 Ci (Auto) Orient Blue 61k
    11 e90 328i Space Gray
    18 F15 X5 35i XDrive White
    Past
    00 e38 740 i (Auto) Titanium Silver
    94 e31 840 Ci (6 speed conv.) Avus Blau (This car was Awesome!)
    03 e46 325 Ci (Auto) Jet Black
    91 e31 850i (Auto) Diamond Black, Yes, two!
    00 e39 528i (Auto) Jet Black
    92 e36 325i (Auto) Laguna Green
  10. #85
    Nov 2013
    Whitney, TX
    97 850CI
    280 HP. On par with most 4 cylinders today. What were they thinking?
    Desecrator of all things Sacred
  11. #86
    The OC, CA
    95 840Ci
    Aww, C'mon guys 282 according to BMW.
    Current
    Past
  12. #87
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Getting the M73 cleaned up with all the M70 parts! Don't mind the nuclear fall out suite
  13. #88
    Mar 2016
    Tyler, TX
    1992 E31 850i
    Looks great! Extra props for doing it in that weather -- that's wanting it bad. My blood has thinned back out since my days where it snows.
    I also like the organic jackstand supporting the car behind you. No Prop 65 warning necessary.
    Cheers, John
  14. #89
    Jul 2014
    Westfield, IN
    '91 e31 M70
    Finally back from a rash of travel the last month and looking to make some progress this weekend too.
    @dragon - have you sealed up the secondary air pump bungs on the exhaust manifold yet? Did you pull the exhaust manifolds and replace the gaskets or just leave them in place?
  15. #90
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by dukegrad98 View Post
    Cheers, John
    "organic jackstand" hahahaha
    Yes those are welded up. Just left the manifold in place, they are not know to ever leak.
  16. #91
    Jul 2017
    San Francisco
    540i
    baking soda blaster?
  17. #92
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by Reggieleemorton View Post
    Sand.
  18. #93
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Upper and lower oil pans have been swapped in along with the m70 oil pump, and engine mount brackets swapped, engine re timed. Decided to have some engine parts painted. Its coming along.
  19. #94
    Jul 2017
    San Francisco
    540i
    Have you found a 6speed?
  20. #95
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Engine is almost ready, just missing a few seals and still need to powder coat intakes and valve covers. M73 wp has to be retained. Also the 2 rear m70 manifolds bolt right up to m73 block, the front ones down pipe has to be modded.
  21. #96
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Will stick with auto and an upgraded differential.
  22. #97
    Jul 2017
    San Francisco
    540i
    which tranny? whats the name?
    Im rooting for you, man... show us how its done, bro!
  23. #98
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Standard 4hp24. Thanks!
  24. #99
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Front m70 manifolds do not bolt on to the m73 heads. The rear manifolds are plug and play. Front M73 flanges cut and welded onto the m70 manifolds. Exhaust system finished.
    Also got a set on new engine mounts, old ones were compressed and tired.
  25. #100
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Home stretch!!
  1. The Tranny Swap Begins...
    By pianoman90 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-18-2005, 01:12 PM
  2. Let the post whoring begin!!!!!
    By greateratlanta in forum Georgia sponsored by Harrison Motorsports
    Last Post: 07-02-2004, 06:54 PM
  3. Let the 0\/\/n4g3 begin...
    By Gop-Dogg in forum 1988 - 1996 (E34)
    Last Post: 02-19-2004, 09:21 AM
  4. Let the trash talking begin; 3.0 vs 3.2
    By Cosmos///95Lux in forum 1992 - 1999 M3 (E36)
    Last Post: 06-12-2001, 01:54 AM
