Results 1 to 4 of 4
Thread: Battery replacement
    Novato, CA
    Red 3.0i
    Battery replacement
    what do you have to do to reset the computer when you replace the battery?
    Seneca, SC
    2007 750i BMW; 2003 Z4 3.0 BMW; 2002 Lexus LS430;
    No.
    Atlanta, GA
    06 M Roadster Red/Blk
    Quote Originally Posted by midnightrambler View Post
    Good news!!! No need to reset the computer in an E85/86 Z4. All you need to do is reset the auto windows and clock(if you use a tender while swapping you can avoid this as well.)
    Atlanta, GA
    '07 Z4 3.0si Roadster
    Quote Originally Posted by chickdr View Post
    ...if you use a tender while swapping you can avoid this as well.)...
    Uh, no. A genuine Deltran Battery Tender (also rebranded as a BMW charger) will detect an open circuit when you disconnect the old battery and will shut off. Ask me how I know this .
    On the other hand, a pair of jumper cables connected to a second battery using the underhood connectors should work just fine.
  1. Dead Battery... Replacement Options?
    By Kevlar in forum 1992 - 1999 M3 (E36)
    Last Post: 01-31-2004, 07:43 PM
  2. $400 battery replacement...
    By platooka in forum 1992 - 1999 M3 (E36)
    Last Post: 12-18-2003, 03:52 PM
  3. Battery replacement for BMW 318ic!!!!!!!!!!!!!!!!!!!!!!!
    By bmw5150 in forum 1991 - 1999 (E36)
    Last Post: 03-30-2003, 12:03 AM
  4. Battery replacement for E36 M3
    By silverBimmer in forum 1991 - 1999 (E36)
    Last Post: 03-29-2003, 12:12 PM
  5. My battery replacement update.
    By dbruce in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2001, 12:13 PM
