The plan is to build a pro-drift car installing a 2JZ-GTE-VVTi on a E92. I'm searching for a swap kit, mainly engine mounts. 18Fab used to make such mounts but that shop closed down some time ago. My other concern is the turbo manifold, the plan is to install a single turbo, a v-band Gen2 Garrett, I'm afraid that not any manifold would fit. I'd appreciate your feedback regarding the engine mounts & manifold.
90 views & no reply! My main requirement is for the engine mounts & the single turbo manifold as I don't think that any 2JZ manifold would fit the E92 engine bay. I'd appreciate your feedback.
a few would work. Mounts are easy. I feel like if you can't fab up some mounts, building this Pro Drift car is a bit outside of your scope.
Start at the transmission and work forward. Then move the engine around a few times and solid mount it to the chassis. GATEBIL guys have done it as have tons of the european drifters.
Good luck with your swap!
Yes you're right, mounts should be easy, in case I don't find a shop that supplies I would fabricate them myself. I will be fabricating the transmission mounts myself anyway since I'm getting a sequential gearbox. My other concern is the exhaust manifold, you said that a few would work, any tips, hints about those?
