Results 1 to 15 of 15
Thread: Bought new Used 97 M3 - Keys arent matching.
    Jan 2016
    E46 M3 , E34 525iT
    So I purchased an 1997 M3 Sedan over the weekend. And the door keys, ignition, and the Trunk release key doesnt match.
    What is the best way handle this? Can I just go to my dealership the original key my VIN is assigned to and Tumbler/cylinder?
    If i swap out the ignition cylinder/tumber, does it affect the EWS? Does anything need to be reprogramed?
    Oct 2003
    Seattle
    99 M3
    Typically, a copy of registration (in your name) and a copy of drivers license is required to purchase keys/tumbler. Door and trunk lock can be re-keyed with a tumbler repair kit.
    If the current ignition key is not for your VIN, there may be a larger issue with EWS/ECU system and any VIN based key you obtain.
    http://www.unofficialbmw.com/images/BMW_EWS.pdf
    Jan 2016
    E46 M3 , E34 525iT
    Quote Originally Posted by bluptgm3 View Post
    My current key works right now for the ignition/starting the car. Would it just be easier for me to just continue using that key and re-keying that unmatching sets with the tumbler repair kit?
    Oct 2003
    Seattle
    99 M3
    The question would be do you have a spare key for ignition, and are they VIN matched, meaning IF you went to BMW and ordered a key it would work in the ignition and is your current EWS also VIN matched.
    If yes, then re-key doors and trunk with repair kits.
    Dec 2016
    vero beach, FL
    1997 328ic
    You sure you don't have valet key? That wouldn't work on trunk or glovebox
    m50 mani / AA c38-81 stage 2 / 12psi / AEM progressive w/m kit / stg3 SB endurance clutch + SS / 3.38 LSD / cdv + asc delete / stromung catback + cat delete / ebay coilovers + GC RSMs / square CSL wheels / ski-pass 8" sub
    Jan 2016
    E46 M3 , E34 525iT
    The question would be do you have a spare key for ignition, and are they VIN matched, meaning IF you went to BMW and ordered a key it would work in the ignition and your current EWS is also VIN matched.
    I just have 1 key. The key just works for the ignition. it doesnt unlock the doors, glove box, the trunk. I looked at the doors and the trunk, which the VINs match the car.
    Im assuming at some point the tumbbler/cylinder/ignition key probably had issues and they changed it over somehow?
    Quote Originally Posted by verobeach97 View Post
    maybe, but it doesnt open the driver/passenger door.
    Dec 2016
    vero beach, FL
    1997 328ic
    Valet key should work on drivers door and ignition only. It's grey color. http://www.bimmerwerkz.com/forum/faq...a-58212.html#/
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by dunkman23 View Post
    Read the link I included above.
    Due to EWS issues, I can’t imagine obtaining a key, tumbler, matching EWS module, from another car and having the ECU aligned to match.
    A few years back my drivers door lock and trunk lock tumbler got really dry and stopped working. I found a really high quality lock lubricant and applied it several times and the locks have been working fine ever since....now at 268K miles.
    The valet key with bad door tumbler gets my vote.
    Jan 2016
    E46 M3 , E34 525iT
    Hmmm .... my key is black. I wonder if it is an aftermarket key.
    Thanks ! I'm going to order another key and see what happens.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    You'll need a working key to get the lock out of the doors to even use the cylinder repair kit. Or a whole new door handle (which usually includes a new lock and key, so you could THEN use the tumbler repair kit and re-key the tumbler).
    Feb 2001
    So Cal
    1997 M3 Sedan
    Quote Originally Posted by blckstrm View Post
    Having just replaced my door handle, I can assure you it does NOT come with a key, even when you order the new lock to match your existing key. And having done that repair, I concur that buying a new key, even for $50-$100, is going to be well worth the money compared to the time spent trying to change the locks.
    97 Estoril/Black M3/4/5
    "Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
    Road & Track May 1997, testing the M3 Sedan
    Oct 2003
    Seattle
    99 M3
    Can this be accomplished by a locksmith without a proper key?
    Jan 2016
    E46 M3 , E34 525iT
    So I ordered a new OEM Vin matching key from BMW. This Key now opens glove box, trunk, and passenger side door. It doesn't start the car unfortunately. I pulled out the DME/ECU and it matches the the cars Vin. Do you guys think just swapping out the Tumbler to match the OEM Key would fix this issue?
    Jul 2003
    Texas
    1997 M3/4/A
    Are you saying the new key does not turn/match the ignition? If it doesn’t, you can get a matching tumbler from the dealer. I think I paid 155ish a little over a year ago. It will not affect EWS by just swapping tumblers.
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    just repin the tumbler and done
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
  1. Just bought new(used) '01 525i...
    By Alpine003 in forum 1996 - 2003 (E39)
    Last Post: 12-23-2003, 10:02 AM
  2. Looking at a used '97 M3.. tire concern?
    By almostki in forum 1992 - 1999 M3 (E36)
    Last Post: 01-19-2003, 12:56 PM
  3. New Member - 97 M3
    By Roids66 in forum BMW Rides & Events
    Last Post: 11-26-2002, 04:18 PM
  4. Just bought new(used) car, good deal?
    By NAH325i in forum 1991 - 1999 (E36)
    Last Post: 05-21-2002, 12:12 AM
  5. Used 97 M3 pressure plate and clutch disc
    By nicholas in forum BMW Parts For Sale
    Last Post: 09-18-2001, 12:46 PM
