2004 330. When I do a cold start I've started hearing a groaning noise. It's coming from the area around the brake booster. It's definitely not the SAP. It almost sounds like an HVAC door/flap that is struggling to open or close. I've tried starting the car with the hood open a couple times but so far I can't get it to reproduce the noise with the hood open. It's still intermittent. Any ideas?
Try turning the ignition to run but without starting the engine. This supplies power to everything in the car. Does the noise occur?
Lee - check your DISA flap.
https://www.google.com/search?q=disa...ih=757#imgrc=_
Thanks. I actually have a spare disa unit. I'll swap it in and report back.
Replacing the DISA had no effect. Still groans and it's doing it while I drive. Seems to happen most when I let off the gas. Performance isn't affected nothing strange going on just that noise.
Shot in the dark: Check your belts and pulleys.
Johnny Murray
Somebody commented that an oil separator packing it in had a "Chewbaca-kind of sound". Sounds like my wife's sport wagon, which is drinking oil like nobody's business. Fortunately, I have a cold-weather oil separator sitting on shelf. Unfortunately, it's a bugger of a job to replace it without taking out the intake manifold.
I replaced the oil separator and all those tubes about 2000 miles ago but I did not buy an OEM version. I have definitely considered this as the cause.
Yes it's a bear to access it but I might bite the bullet and swap in a new one.
While it's groaning at idle pull the dipstick or loosen the oil cap slightly does the noise change
Both belt driven...an AC unit...and separate Alternator-Power steering-water pump...serpentine belt system...include (idler pulley wheels and belt tensioners......When these mechanical items become worn...they emit similar in your observation.
