I know this question has been asked but I could not find a solid answer (or at least one that worked for me)
I have a 2007 335i Coupe and my drivers side controls do not work. This includes both the windows and the power mirrors. The key fob will also not unlock or lock the car but putting the actual key in the door lock does work. I tried the fuses and relays but to no success. If anyone could help me out that would be greatly appreciated.
The most likely cause of the switches not working would be the switch unit itself. You may have a separate problem with the key fob, or it could be related. This is where a proper diagnosis is worth it's weight as opposed to just throwing parts at it.
I took the car into my mechanic and he told me that the switch unit will need to be replaced, however, after putting back my door panel. I now have a no key light and the trunk will not lock or unlock using either the button or key fob!!
Replaced the window switch and it still does not work.
I have a similar problem. My drivers window does not work. Replaced motor and master switch. All fuses seem to be fine. The door lock and mirror work but the window and speakers do not. Can anybody help?
