Results 1 to 4 of 4
Thread: Mass Air Flow Sensor questions
    Jun 2014
    MA
    BMW
    Could use some advice...
    Got both SES 171/174 error codes on a 2005 330i.
    Cleaned MAF and checked hoses.
    Is there a way to bench test a MAF sensor? I saw a test where you disconnect the MAF and it there is no change in the way the engine is running it is bad. Also read about a voltage and a atmospheric pressure test.
    Also, where's a good place to get a new MAF at a reasonable price?
    Seems like prices are all over the place for a new replacement.
    Thanks in advance!!!
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Quote Originally Posted by Lilredpo View Post
    FCP Euro provides a LIFETIME warranty for any part they sell. An OEM MAF is not cheap ($225 for VDO/Seimens or $300 for one with a BMW logo). FWIW - I've had a cheap EBay MAF in my car for almost 2000 miles with no issues.
    Before you start throwing parts at your car for what is the most common codes a M54Bxx will throw, have the car smoke tested for vacuum leaks. A 'soft failing' Fuel Pump can cause those codes too. I battled these very codes for a while myself but since I installed a new Fuel Pump and replaced the DISA (which failed a vacuum test), I've not seen them again.
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    failed MAF's are extremely rare unless you've been running an oiled air filter.
    Its almost always vacuum leaks, have it smoke tested.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Jan 2014
    USA
    04 ZHP, 83 320i, 00 M5
    ^ this and
    Get MAF cleaner. Don't use brakekleen or anything else on it and don't touch the wire with your hands.
  1. MAF (mass air flow sensor) question!
    By mandito219 in forum 1996 - 2003 (E39)
    Last Post: 11-12-2012, 01:17 PM
  2. Ebay Mass Air Flow Sensor; Quick Question
    By DrinkCoffee in forum 1991 - 1999 (E36)
    Last Post: 11-29-2010, 10:39 AM
  3. Question on Mass Air Flow sensor for e30 325is
    By e30man23 in forum 1983 - 1991 (E30)
    Last Post: 03-30-2007, 11:37 AM
  4. HFM Mass Air Flow Sensor question????
    By sulax22 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-27-2006, 07:01 PM
  5. Question about 318 turbo and mass air flow sensor?? ? ?
    By warchieft2k in forum Forced Induction
    Last Post: 06-15-2004, 05:32 PM
