Page 9 of 9 FirstFirst 123456789
Results 201 to 224 of 224
Thread: Fan Delete and Now Overheating
  1. #201
    Bay Area, Killa Kali
    2002 M Coupe, 2019 F31
    Quote Originally Posted by rf900rkw View Post
    Damon, Andrew, where have you been hiding?
    On an S54, I would go with the 80/88 fan switch.
    Thanks Randy, parts on order! Anyone want a free mechnical fan? Just pay postage
    I've been around and checking the boards fairly regularly. I just haven't been as involved with the car as my wife and I bought a house late last year and that has taken priority. Hope you and the rest of the community are doing well.
    -2023 Honda Odyssey Elite
    -2019 F31 Individual (M-Sport, Prem, Exec, Track)
    -2004 Honda CRV
    -2002 S54 M Coupé
  2. #202
    Ellay, CA
    BMW Z3 3.0 VF SC'd
    Quote Originally Posted by CaliAgents View Post
    ...would you let that AP Racing brakeset go if I just pay postage?
    One can dream!
    "You don't win silver....you lose gold."
  3. #203
    Quote Originally Posted by danomite View Post
    One can dream!
    My beloved Pro 5000+ setup is long gone now =( Maybe the current owner would be so kind to let it go for postage
    -2004 Honda CRV
    -2002 S54 M Coupé
  4. #204
    On an S54 I would say the 80/88C switch is pretty necessary...
    Tried mine out without the mechanical fan after cooling system work recently and it ran pretty hot. Still in the correct temperature range... but on the hot side of that range for sure. The lower temp switch will keep everything at a safe temp at all times.
    PRICE CUT on ALL FABRICS
  5. #205
    Dec 2017
    Houston
    01 M5, 02 330ci, 03 M3
    The aux fan is more than adequate for even desert traffic conditions, as stated here.
    For clarification's sake, would this be with a thermostat like an 80C and water wetter, or otherwise stock cooling? I haven't seen much mention of changing thermostats with aux fans.
    I'm going through a high mileage e36 328i and I want to make it as reliable as possible. Clutch fan will come out first then probably adding a puller fan + lower rad hose sensor before summer.
  6. #206
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Stock, Aeko. I'm not sure on the E36 for this topic, but I suspect it's the same situation as in the Z3.
  7. #207
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Stock will work just fine. Of the popular "upgrades" for an M52, the 80c fan switch would be most useful. I run a 80c thermostat purely because supercharged. Not needed for stock. And water wetter is a waste of time.
  8. #208
    Dec 2017
    Houston
    Noted. I figured I would run a lower thermostat temp if I decide to opt for performance upgrades. Thank you very much! Also hope your treatment goes well.
  9. #209
    Feb 2012
    MN
    1997 z3 roadster
    Quote Originally Posted by Aeko View Post
    We've got a lot of great people on this forum but we are fortunate to have a couple of Randys posting regularly!
    It's a Hybrid--Burns Gas and Rubber
  10. #210
    After performing not only the mechanical fan delete but also the below, I wanted to update this thread with nothing but positive results.
    -OE BMW AC and alternator/WP belts (original bits were showing cracks, especially the AC belt)
    -OE BMW Motorsport fan delete nut
    -OE BMW 80/88C fan switch
    -coolant flush (block and radiator)
    I monitored temps before the mechanical fan delete and afterwards with an OBDII Ultragauge and I can safely say there is absolutely zero cooling issues. The biggest ticket for me was peace of mind knowing that I had an unstable component underneath the hood removed for good. Last thing I need is a fan tearing up my cooling system, denting up the hood, and leaving me stranded yadidimean?! Thanks fellas, yeeeeeeeeeeeee!
    -2004 Honda CRV
    -2002 S54 M Coupé
  11. #211
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    You don't have any coolant in the block. If you filled it using a youtube vid, you did it wrong. If you filled it using any instructions that tell you to start the engine before the system is totally full, you did it wrong. Cold engine. Take the upper hose off, and stick it on the thermostat housing pointed up. Use this new point to pour coolant directly into the engine. Keep pouring until coolant runs out of the open radiator neck. Reinstall hose. Finish topping up, squeezing hoses to burp the last bit of air out. Put the cap on, start it up. Note that no where in here did I mention the bleeder; it's a waste of time.
    I tried this method after replacing all cooling system - it didn't worked as good as I expected. After starting the engine after heater was blowing cold air, squeezing hoses didn't helped much. After idling and squeezing hoses for 20 minutes revved the car for about 2-3 minutes to 3k and heater core finally started to fill with coolant and blow hot air. Seems like even after that there was still some air inside as engine coolant temp was still fluctuating a bit couple days and had to fill up some coolant (up to 1L). After that seems that all air was finally out.
  12. #212
    Jun 2016
    Odessa, TX
    I recommend filling it, squeezing hoses, and screaming at it about the futility of life in general. Worked for me.
  13. #213
    Dec 2007
    Great Dismal Swamp
    I've said it before, but it fits here too. Each engine used in the Z3 has its own quirks on coolant filling. The M52 with the low header tank is the hardest in general. The M54 is by far the easiest, as long as you don't pull the block drain. Tricks that work well on one may be redundant on another.... or blow up in your face.
  14. #214
    Aug 2013
    Terre Haute Indiana
    1998 Z3 2.8
    When I had to change the cheap aluminum thermostat housing that was leaking on my '98 2.8, I invested in an Airlift vacuum unit. Made refilling the cooling system a breeze. Simply attach the unit to your cooling system, let it pull a vacuum (which also tests for leaks), flip a switch, and let the vacuum pull coolant into the system. I had absolutely no issues, and I'd never again do any cooling system work without it.
  15. #215
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by Mark Bielick View Post
    +1 on S52
  16. #216
    Jun 2016
    Odessa, TX
    I used the airlift system on my M52tu and it fell short of getting all the air out. I'm cursed, though.
  17. #217
    Redding Calif
    1999 Z3 2.5L 5sp
    Quote Originally Posted by LannVouivre View Post
    Don't know if you're cursed or not.. ;-) ... but I also have a M52TU(B25) motor, and think the bleeding of the system is easy/straightforward (though I might be deluded) and will leave to Randy to correct... but I put the nose of the Z on ramps, lifting it 8"; bring the system temp up to operating temp; set the heater to full hot and fan to "1"; fill the system from the expansion tank; run the engine at 2500-3000rpm; and give the top radiator hose a good couple squeezes... and why I think this works is: heater works at idle, and have never had out of range operating temps... which to me says there is no air trapped in the system... the other thing I do per Randy's reverse engineering, is to keep the expansion tank at the low mark, meaning that the system is operating at a lower pressure, stressing hoses etc less.
  18. #218
    Jun 2016
    Odessa, TX
    I can get the air out, just not using the airlift system.
  19. #219
    Jul 2019
    SoCal
    1997 BMW Z3 1.9
    Question: For those who changed their radiator (mine is nissens), did you still have to use a thread sealant for the auxiliary fan switch on the radiator? The auxiliary fan switch sensor has a metal gasket but I heard even with the metal gasket, it's still best to use a thread sealant to ensure there's no leak. Also the same with the coolant temperature sensor and oil pressure sensor, I heard.
    FCP Euro recommended me this:
    https://www.fcpeuro.com/products/hig...-sealant-59235
  20. #220
    SW Florida
    99-01 M Cpe & Rdts, X5M
    You don't need a thread sealant, just the alum or copper crush washer. You can verify the sealing surface is flat on the radiator's threaded bung.
  21. #221
    Jul 2019
    SoCal
    1997 BMW Z3 1.9
    Quote Originally Posted by Randy Forbes View Post
    Hey Randy, so this is what I see in my Nissens right now. It's a crush washer on a hard plastic fitting? I don't get it. I probably would have to use thread sealant. Unless it really works this way?
  22. #222
    Thats the plug that blocks the temp switch port during shipping isnt it? Thats where the fan temp switch will go, needs to be swapped from old radiator. They do just seal with the crush washer
  23. #223
    Mar 2016
    Detroit
    Z4M Coupe
    Quote Originally Posted by RayBallen View Post
    I just put in a Nissen radiator. Real OEM calls for a crush washer part# 32411093596 on the temp switch so I put that in. The radiator and switch that was previously on the car didn’t have a washer so I questioned whether it was needed. I went ahead and put the washer on with no thread sealant. Can’t comment on whether it leaks or no since I haven’t filled the system yet. Waiting on a thermostat housing.
  24. #224
    Nov 2011
    hickory, nc
    2000 bmw z3 M
    i had a reoccurring overheating problem-no fan delete. using rf900rkw's post advising to:
    this did the trick for me.
  1. Replaced clutch fan and now overheating ?
    By elvirb87 in forum 1996 - 2003 (E39)
    Last Post: 06-23-2011, 10:44 AM
  2. Fan Delete WIERD instant overheating!
    By natopotato in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-04-2003, 09:35 PM
  3. Fender Rolling Fan Delete And More!
    By Franchise in forum California sponsored by Avus Autosport
    Last Post: 07-26-2003, 03:20 AM
  4. Fan Delete and Pulleys
    By themadhatter in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-05-2003, 09:27 PM
  5. fan delete and the track
    By ak555 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-29-2003, 02:59 PM
