Results 1 to 6 of 6
Thread: 1987 730 ABS light on cluster.
    Nov 2016
    Iceland
    Bmw 545 2004
    Hey i got an abs ligh on my cluster in my euro m30b30 and there was a very experienced bmw workshop here in iceland wo connected the car to a diaagnostic tool and there was a problem connecting it to the modules in the car. so they tried another bmw scan tool for old bmw and there was also problem getting signal from from the cars computers. They also tried connecting to the transmission and there was no answer there too. I was hoping anyone here could help me find out what's wrong wth the car.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    use a multimeter to test the ABS sensors, here a detailed instruction by a German electr. engineer on the 7 forum, translate that http://www.7-forum.com/forum/showthread.html?t=9358
    Nov 2016
    Iceland
    Bmw 545 2004
    Okay, then I can see which one of the abs sensors is faulty. But what could be wrong if a obd scanner can not communicate with the car or the computer's?
    Jan 2005
    Japan
    Happens quite often on older BMW that the tool does not handshake with the newer versions scanner. For a 1987 E32 you need an older version scan tool. That car is pre-OBD. http://www.meeknet.co.uk/e38/Diagnostics.htm
    1987 730 with M30B30 probably still has the older version Motronic M1.1, there the number of faults stored is very limited.
    Nov 2016
    Iceland
    Bmw 545 2004
    Like I wrote in the first place the workshop connected the car to a older version BMW scan tool also with no luck. The mechanic that was working on the car was going to check a wiring diagram because he thought that the communication wire for the computers was faulty. What wire should I check?
    Jan 2005
    Japan
    wiring diagrams are here http://shark.armchair.mb.ca/~dave/BMW/e32/
    I can only assume what the mechanic was looking for, the 20-pin diagnosis port? Here is the pinout of the 20-pin diagnosis port https://www.bimmerforums.com/forum/s...5-OBD-Port-Mod
  1. Completely weirded out - ABS light on with different cluster
    By ClayMan in forum 1991 - 1999 (E36)
    Last Post: 05-29-2009, 03:46 PM
  2. ABS light on with used replacement cluster
    By lo flyn in forum 1992 - 1999 M3 (E36)
    Last Post: 10-07-2006, 07:52 PM
  3. ABS Light on on my instrument cluster... what does this mean!?
    By chockomonkey in forum 1991 - 1999 (E36)
    Last Post: 10-31-2004, 04:31 AM
  4. ABS Light On
    By Malaka in forum 1991 - 1999 (E36)
    Last Post: 05-14-2002, 11:43 PM
  5. ABS Light on '95 M3
    By Bugatti in forum 1992 - 1999 M3 (E36)
    Last Post: 02-01-2002, 06:34 PM
