Results 1 to 11 of 11
Thread: Engine Light on Dash
    Dec 2017
    Mwinilunga Zambia
    BMW 320i MSport 2003
    Question Engine Light on Dash
    Hi,
    I had a fuel pump problem a week ago. had it replaced.
    Had a service done also at same time. Changed fuel and air filters as well as engine oil.
    I drove up to 600 km and then the engine light came on. following day, starting the engine gave a shaky vibration as if the engine not firing properly. Had to shut it down and I think it was gonna shut down anyway.
    There is no diagnostic service in my town. What could be the problem?
    before buying the car, I read that it must never be driven on low fuel. That happened while bringing it into the country. The agent ran out of gas and had to bring fuel to the road side.
    Could this be the cause? I mean, could this be the fuel pump root cause?
    And what could be the issue with the engine light?
    I have not changed plugs yet.
    It's an E46 320i M Sport 6 cylinder engine, 2003.
    I'm considering changing plugs and see if i can drive to the nearest service point about 300km.
    dworthy's Avatar
    Nov 2010
    Baumholder, Germany
    05 325it 05 M3 95 318is
    Welcome to the Forum!
    Without knowing what the codes are, it would be like trying to fish without a hook. Being that you live in a remote area, it would be worth buying a scanner. While I don't like pocket scanners, it is better than nothing, however if you have an older laptop with Windows XP Pro, you can download INPA from the internet for Free. Then all you would need is a INPA cable, and they tend to cost the same as a pocket scanner, around 20 bucks.
    P.S. You can also take a look in the Diagnostic Software subforum too: https://www.bimmerforums.com/forum/f...ostic-Software
    Darin
    Current:
    05 325it Electric Red(438)/Gray(N6TT) ZCW, ZSP 5sp Manual Back set cover, trunk mat, Euro Infra-Rot front windshield, and mud flaps! Mr. Wagon (Original Owner)
    05 M3 Imolarot II(405)/Gray(N5TT) ZCW, ZPP 6sp Manual C.F. Lip, CSL diffuser, Euro Infra-Rot front windshield and a trunkliner! Mr. Go_Fast (Stored for the Winter, 2nd Owner)
    95 318is Montreal Blue Met (297)/Beige(K1SN) a work in progress - Winter Car! (10th Owner; That is what happens when it gets passed around by Soldiers!)
    Past:
    84 M535i gray market Burgandy Rot Met/Black Leather Lowered by Intrax on bilies, poly everywhere, B&B cat back system, K&N, and a hitch! Da Beast - Still running w/375k+! (2nd Owner)
    91 316i euro Tizianrot/Gray cloth - E-36 w/M-40 motor, such a beater, but great on gas! Best was 38 MPG (2nd Owner)
    79 525 euro Green/Green RIP
    M-Flight Member
    Apr 2009
    Vancouver Isl, BC, Canada
    2004 330ci
    Agreed you need to determine the codes. Guessing will only get extremely expensive.
    Current:
    - 04 330CI
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci
    Dec 2017
    Mwinilunga Zambia
    Thanks Dworthy.
    I actually ordered a scanner and I am waiting for it perhaps in next two weeks I should receive it.
    I already have VMware ( if thats what you imply) but it sure needs a cable.
    I have another concern though.
    Can i remove the battery without causing other problems?
    I have heard some people saying the battery must never be removed as it could damage the OBC.
    It is still in good condistion (green).
    Just thought weeks of being in park could drain the battery.
    Appreciate your response.
    I just went outside of cellular coverage for some rural work.
    Thanks again
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Yes, you can remove the battery without damaging anything. The clock will have to be reset and you’ll loose the radio station presets. But nothing else will happen.
    Dec 2017
    Mwinilunga Zambia
    Thanks a lot for your help.
    Dec 2017
    Mwinilunga Zambia
    Hi,
    I have received the diagnosis gadgets. Both INPA and PA 1.4.
    I got the following readings after scanning. I have left what's in the shadow memory.
    DME -> 08/B2 - Air mass flow sensor signal, short circuit to negative or open circuit
    E4/B1 - Oxygen sensor controller, bank 2, deviation too great, deviation rich
    E3/B1 - Oxygen sensor controller, bank 1, deviation too great, deviation rich
    F2/B2 - Misfire, cylinder 5, misfiring during warm up, worsening emissions (Misfire CARB_B1)
    1D/A2 - Ignition activation, cylinder 1, spark duration too short.
    I thought I would be able to decode the statements easily. Turns out there is need for experience to now what to check and maybe replace.
    Your help is always appreciated.
    Dec 2017
    Mwinilunga Zambia
    They are from the PA 1.4 SCANNER
    dworthy's Avatar
    Nov 2010
    Baumholder, Germany
    Sorry but I am no a PA Soft guy, but a INPA person.
    So if that is in Shadow memory, that would tell me that is happened once or twice and isn't current.
    However I would use INPA to clear all the modules and take it for a drive. After a drive, check to see if anything came back.
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2017
    Mwinilunga Zambia
    OK
    Thanks still
    Dec 2017
    Mwinilunga Zambia
    I ll try the INPA and see what it "says"
  1. Help! engine cut out briefly? Left most yellow light on dash flashed?
    By Delphin Metalic in forum 1983 - 1991 (E30)
    Last Post: 06-04-2010, 04:10 PM
  2. check engine light on front dash
    By bmw 325i guy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-25-2010, 12:07 PM
  3. Check engine light on '96 328i
    By lazarost in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-07-2002, 02:07 PM
  4. Check engine light on! NEED HELP PLEASE :)
    By JacobStile in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-14-2002, 03:53 AM
  5. Check Engine Light on 96 M3
    By DAM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-29-2001, 12:15 PM
