Power Steering Hoses Improperly Connected
Acquired a 99 528it. It was leaking power steering fluid so decided to change reservoir/filter and hoses. Discovered that the return pipe (part#32411093149) and the radiator return line (part#32411094306) were connected to the wrong ends of the cooling coil. The radiator return line was connected to the bottom while the return pipe was connected to the top. Despite the leak which I only noticed a few days after I bought the car I actually drove the car around with no apparent steering problems. I connected the new hoses according to realoem but I'm curious. Did it matter if the connections to the cooling coil were swapped?
2013 328i vert
2003 325i SULEV sedan
1999 528i wagon
