Results 1 to 6 of 6
Thread: Tools for regular maintenance
    Oct 2017
    Maryland
    E46 M3
    Smile Tools for regular maintenance
    Hello! Brand new to the forum. I'm picking up an E46 M3 here in the coming months and I was wondering what tools i should start stocking up on to keep around for the routine maintenance I know it's going to need. I really want to stay on top of things and keep the motor running as long as possible. I don't want to get into anything major like valve adjustments, just oil changes, brakes, tire rotations, and the little odd jobs along the way. I can't wait to join the Owners club and finally transcend my enthusiast status after 13 years. Thanks in advance!
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Hey Tyler... did I guess right? Welcome and congrats on the new to you car. You're wise in doing as much of the upkeep as possible for a number of reasons. I'll leave the specific tool suggestions to others, but try to 'buy once cry once.
    A decent floor jack and at least two stout jack stands will be on your list. Sears sells Craftsman tools often with a good price on 'sets'. It can take some research to avoid buying a set that is simply too much.. I'll let dworthy and others join in with some specifics.
    Got pics of that car?
    88M3 AW 43k miles Project FS
    Oct 2017
    Maryland
    E46 M3
    Yep! it's Tyler. Sadly, no pictures of the car, I'm still searching for my perfect one. Since it's been my dream car for so long though and I know it's what i want I just wanted to start getting the tools im going to keep my motivations up need in the mean time. I'm very excited to buy once cry once and Burn My Wallet
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    I do like Craftsman tools, for hand tools come with a lifetime warranty. You need to get the Metric set, for I have yet to find a SAE bolt on a BMW. Also Allen keys, and a star/torx set is useful to, have a look at this: http://www.sears.com/craftsman-450-p...-00999040000P#
    A decent floor jack for the oil change, and if you have to crawl under the car helps out. http://www.sears.com/craftsman-3-ton...p-00950188000P
    I have several thousand dollars worth of tools, and I still don't have everything I want.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Def get the fan clutch tools from ebay, the valve shim tool, full range of Etorx / allen head sockets. 32mm 6pt socket, get a volt meter and at the minimum a handheld diagnostic tool like that of Schwaben $200, or you can grab an FTDI232 VAGCOM cable and the INPA pack from ebay with a computer, or I can send you the zip.
    edit also the nylon interior clip removal tools (cheap) and I torque wrench for all ranges.
    USA
    Mulitiple
    Crasftsman tools are very good, lifetime warranty/replacement and readily available.
    You need a full set of metric box/open end wrenches (6mm-19mm), I also like the ratcheting type box/open end wrenches, 3/8” and 1/2” ratchet, full set of 3/8 and 1/2 sockets (6mm-19mm 3/8”, 16”-24” 1/2”), torque wrenches that span the range from 10ft*lb to 130ft*lb, breaker bar, ratchet extensions of all different lengths. That will get you started but with time you will need Allen sockets and torx type sockets, specialty tools like a large 32mm socket for oil filter cap, etc, etc; you’ll collect those speciality tools as you go along.
    Get a nice jack and good jack stands.
  1. Good Dallas Mechanic/Tech for regular maintenance?
    By dallas5 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-31-2015, 11:04 AM
  2. Service Maintenance Light Reset Tool for e90
    By stephendo in forum Pacific Northwest - US
    Last Post: 10-26-2011, 08:47 AM
  3. Air tools for maintenance and use of key points
    By wasabiLovely in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 08-04-2010, 06:34 PM
  4. Replies: 9
    Last Post: 07-31-2010, 08:45 PM
  5. Special tool for front shock top nut???
    By JBravoM3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-07-2001, 01:32 AM
