I have a 09 550i with roughly 85k which developed a rather large oil leak recently.
Was thinking its the alternator bracket leak but wasnt sure as i get oil dripping down on the floor on both passenger and driver side.
Anything else this could be?
Right side vacuum pump, oil pressure switch upper timing cover valve cover gaskets left side alternator plate gasket, upper timing cover, valve cover gaskets
Take a look. It should be quite easy to spot. Keep in mind the paneling on the undercarriage will divert the oil to the sides and back so it's not a good indicator of the actual oil leak.
My alternator gasket blew on my 545i. Either get it fixed soon, or if you can, DIY because its a $5 gasket (but a bitch to get at!)
