They want $180 PER intake seal for the M70??? Thats... calculating... $720 total!
Has anyone tried sealant? I know Sean from Johan and Seans E32 Page used sealant on both sides of the gaskets with good results, but what are the long term results? A lot of work if it only lasts a few months or a year.
BMW 7er Website www.7er.com
1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
Sealant or supporting silicone gaskets only work if the original gaskets are free of major cracks. If they have lots of cracks, air can get around the sealant.
______________________________
1992 750iL
Sealant works 99.9% of the time, and it did for me.
yes, we so far never needed to buy new gaskets, have done 6 M70 this year, and many the years before, including my one when we replaced the valve gaskets. We never order new seals, just use liquid seal.
https://www.bimmerforums.com/forum/s...ht=intake+seal
Sealant it is then. Thank you, wasn't sure on longevity but it seems to be the right path. Any particular sealant or just any gasket sealant is good
+1 on Reinzosil. Its remarkably better than RTV. I used RTV and the manifolds came off easily when I had to remove them for valve train work. With Reinzosil, they were a total pain to remove. But that tells me they sealed well and the bond was strong. Look up proper directions for using them on the intakes. It takes time to seal them right (apply, setup, place, wait, tighten, cure time is 24 hours, etc).
1992 750iL
we use some liquid seal from Toyota, because easiest to get here in Japan, no problem at all.
