Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 112
Thread: Great deal on SuperSprint @Turner/ECS
  1. #51
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Ditched my Magnaflow and got my Supersprint system on yesterday. A bit of tweaking to do still...I realized my rear-most rubber hangers were a bit shot, but can probably dial it in perfect in another hour or so. I missed the boat on the 50% off sale (sounds like I got my system before a lot of the diligent members here even), but found a brand new sealed system local to me for a deal I couldn't pass up. The scenery at the seller's shop made it a heck of a fun job. He even let me use his lift and one of his mechanics at no charge. If you're reading this, thanks again Alex!
    I guess I can offer pointers when the rest of you go to put your systems on. Truly bolt-on, but picked up a couple tricks. My head worked great to hold the mufflers in place while I did up some bolts. To my knowledge the kit does NOT come with bolts to attach the muffler hangers to your rubber hangers, so you'll need to come up with something there. However, I don't know exactly when my system was purchased, so SS may have rectified this.
    20171217_123502.jpg20171217_141840.jpg20171217_141854.jpg20171217_143221.jpg20171217_113548.jpg
    I was told the exhaust will get a bit louder after about 500 miles (seller has same system on his Coupe), but I was very happy with the initial sound. At WOT, it's glorious...a nice deep refined note. My only problem is now I have 6 mufflers hanging in my garage! Original OEM, the Magnaflows I removed and a set off my work buddy's Z4M. One of them will make it onto the Coupe someday, and we'll probably toss another on a Lemons car or two.
    Nathan in Denver
  2. #52
    Aug 2015
    Denver, CO
    Anyone have any experience with the aftermarket rubber hangers? I can't imagine spending over $100 for 4 OEM hangers. I actually don't recall seeing metal sleeves in mine; could BMW have updated these at some point?
    https://www.ecstuning.com/Search/Sit...h/18211704198/
    Nathan in Denver
  3. #53
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by s8ilver View Post
    All the aftermarket ones I have tried on my E36 failed within 6mo to 1 year. Causing me to replace them again.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  4. #54
    Aug 2015
    Denver, CO
    Good to know. I'll grab OEM and worry about them again in another 18 years. I still think I made out alright on the deal.
    The only annoying thing about the system is the slip connection on the passenger side. It's nice because you can adjust the length (DS is fixed length), but since the top left bolt on PS is fairly unreachable with DS in place, you can only guess on the overall length before you bolt it up. Now I've realized my PS sticks out about 1/2" further than DS (was really hard to notice until it was all bolted up and back on the ground). I think I can just loosen the connection on the clamp and try and move the entire PS forward, but not looking forward to it. Of course, instructions would have helped. All that was in the box was a diagram showing a flange bolting to a car. 100% generic.
    Nathan in Denver
  5. #55
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    My car uses molded rubber hangers with cloth reinforcement inside: PN 18211247422 for $25 each.
    I measured the distance between holes and also bought some generic hangers from Kartboy.com for $8 each. They were blocky and square in profile rather than rounded, looked crude and strong. But I didn't use them.
    BMW MOA 696, BMW CCA 1405
  6. #56
    Aug 2015
    Denver, CO
    Quote Originally Posted by Vintage42 View Post
    18211247422
    I measured the distance between holes and also bought some generic hangers from Kartboy.com. They were square cut not molded, thicker and cruder, and looked stronger, if anything. But I didn't use them.
    Entirely different hanger on the M. M has two studs on the car side that you bolt the hanger to; then you bolt the Supersprint bracket to the hole in the rubber hanger. I don't love the setup, as the Superprint hanger has a very long slotted vertical hole and relies on friction to keep the muffler height held; however the bracket only attaches to one side of the rubber hanger. You basically squish the bracket into the hanger with a nut and bolt, probably prematurely wearing the rubber some. The OEM mufflers have welded round bar that fits in the rubber hanger hole (can't slide vertically). The Supersprint system does allow you tuck the tips up quite high; I can barely get a finger between the top of the tips and bottom of bumper and have a few mm clearance on both sides between tips and bumper cutouts.
    Nathan in Denver
  7. #57
    Texas
    '02 Z3, '09 Mini
    Yes, the supersprints can eat the rubber hangers. One of mine is torn after a couple of years, probably because it had to be contorted in order to get the muffler to sit where I wanted it to. I might take the car to an exhaust shop and get it professionally installed with custom brackets so the hangers can work properly.
  8. #58
    Aug 2015
    Denver, CO
    Yeah I'm working up a bracket to get steel on both sides of the hanger; it would be better if the hanging load was supported in double shear vs. wanting to twist the OEM rubber. This would also keep the mufflers from wanting to sag if the bolt got a little loose somehow.
  9. #59
    Why would you want it that high? Should be about equidistant from the bumper on the side compared to the top
  10. #60
    Aug 2015
    Denver, CO
    Quote Originally Posted by BimmerBreaker View Post
    Gap between sides is only a few mm (80mm tips don't leave a lot of space). I'll post some photos of where mine's at. To me, they look right. We had them lower but it looked like they were sagging a bit. My 4th photo up above is where I stopped. I could have gone higher.
    And my fingers are a bit meaty after years of non-glove wrenching.
    Here's Turner's installed pic vs. mine:
    Hmm, looks like my PS side isn't off as much as theirs...guess it's easier to screw up that slip connection than I thought. Their PS muffler is also sitting way higher than the DS.
    Nathan in Denver
  11. #61
    Greenville, SC
    Several
    I went over budget on my recent MTB purchase and cancelled my Supersprint order before it ever arrived Happy wife, happy life...
    "If the Corvette is a rebellious child of the extended automotive family, the M coupe is the blackest of sheep." - via Car & Driver
  12. #62
    Quote Originally Posted by adonnan View Post
    If it was from the black friday sale I would have bought it. Ah well
  13. #63
    Apr 2006
    Honolulu
    2000 BMW M Coupe
    IBIS....nice!
  14. #64
    San Antonio
    Z3M Coupe & Roadster
    Andy, don't worry happened to me too. Wanted a full exhaust for the RS and decided it was better to not have to explain a huge box showing up at our doorstep.
  15. #65
    Aug 2015
    Denver, CO
    Quote Originally Posted by jajou318 View Post
    Supercharger kits come in much smaller boxes!
    My hobby outside the automotive variety is vintage watches. Those boxes are even smaller and I usually just have them shipped to work. Unknowing wife=happy wife.
    Nathan in Denver
  16. #66
    Greenville, SC
    Several
    Cyber Monday sale, yes - thought about selling after it arrived. Once suspension is fully renovated then maybe I can play with fancy mufflers, but alas - I spend more time with the pedal bikes now.
  17. #67
    Jul 2011
    Baja (not really)
    2000 M Roadster
    I'm still waiting for mine to arrive. Shipping notice said Dec 22nd, and I got an email from ECS today saying it's pushed back until January 19th. So this actually works out--I haven't paid for it yet, but it's OK because I can't drive it for another couple months anyway.
  18. #68
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Yup. I received the same email. Mine were to ship today
  19. #69
    Jul 2011
    Baja (not really)
    2000 M Roadster
    Quote Originally Posted by z3forlife View Post
    I'm not complaining. I basically got the Cyber Monday deal without having to pay for it until well after the holidays, lol
  20. #70
    San Antonio
    if and when she finds out it could equal other things lol.
    I wonder if the canceled orders will be up for grabs at the sale price that way they dont have to store them.
    Sent from my LG-LS997 using Tapatalk
  21. #71
    Aug 2015
    Denver, CO
    She told me as long as I pay my portion of the bills on time, we're good. I think she chooses not to want to know the details of every transaction. Luckily I flip (nearly) as many as I buy. My latest problem is buying pieces that I really like personally, which makes it harder to let go. So far I've been running at about 15x my online savings account return, so...I'll never stop.
    Nathan in Denver
  22. #72
    Dec 2017
    Placitas NM
    98 Z3 1.9, 14 X3 2.8i
    Don't feel too bad if you missed out on the deal.
    They had a big sale on stuff they DIDN'T HAVE, and it's beginning to look like they never will.
    Just got ANOTHER set-back notice, right after I got parts in the mail that are in no way correct, in spite of web site showing them to be specific to my car.
    And I'm SICK of all the stinking emails.
    ETA: found the site AFTER I'd placed an order for the exhaust.
    Oh yeah, Hello!
  23. #73
    San Antonio
    Did you really expect them to have all that over head? These exhausts are made in Italy and they don't control how quick their shipments go through customs.
  24. #74
    Dec 2017
    Placitas NM
    [QUOTE=jajou318;29917139]Did you really expect them to have all that over head? These exhausts are made in Italy and they don't control how quick their shipments go through customs.
    Sent from my LG-LS997 using Tapatalk[/QUOTE
    Yeah-if you’re going to have a big a** sale, you ought to be geared up and ready to deliver in a reasonable time frame.
    Customs likely has little to do with it.
    Just extra pissed because I got the latest delay email right after finding parts with the correct part # in no way fit.
    And hello anyway!
    ETA:
    First got a notice “Awaiting arrival “
    Then got a notice “Warehouse transfer”
    Today’s notice (pushing it out to January) states “Awaiting delivery from local supplier”
    And that’s after I got an email (among the many) last night asking me to submit a review.
    A review for something I’ve never seen.
    This was an impulse purchase ( like I’m sure many were).
    Not a custom-order we don’t know when, if ever,it will get here.
    Gonna hang in there, for a while at least.
    But my frustration is not without cause.
  25. #75
    Wadsworth, Ohio
    BMW
    NMBuffalo Super Sprint has never failed to deliver exhaust to us, many of the systems are built to order and long lead due to this, I'm very sorry about the delays. As for ramping up for a big sale, we did and they did, everyone just was way way more excited for the deal than anyone anticipated.
    -James
  1. Replies: 8
    Last Post: 09-02-2010, 04:24 PM
  2. Great deal on UUC flywheels
    By BMLRacer in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 08-26-2002, 05:00 PM
  3. Great deal on UUC aluminum flywheels
    By BMLRacer in forum 1992 - 1999 M3 (E36)
    Last Post: 08-20-2002, 07:21 PM
  4. Great deal on E36 M3 BRAKES
    By Mauricio in forum 1992 - 1999 M3 (E36)
    Last Post: 11-13-2001, 01:35 PM
  5. Best deal on Supersprint?
    By ALDOGG in forum 1991 - 1999 (E36)
    Last Post: 05-09-2001, 03:51 PM
