Call or Text me; 949-500-8493
I'm located in 93644, not SoCal. California delivery can be arranged.
I can ship. I can provide the E36 M3 tubes in place of the Z3M parts.
This kit as been gone through completely, from Vortech rebuilding the V2 supercharger, to all new bolts and clamps. The parts list is extensive so please read it over thoroughly. What makes this kit rare is that it is for 1996-2000 Z3M Coupe and Roadsters. The supercharger to air filter piping was very much different for these cars and is hard to find. This is intened for use on Z3M, but you can also make the piping work with 1996-1999 M3. Everything here is Plug and Play. An experienced mechanic can have this up and running in a weekend. The ECU included is already loaded with the necessary Dinan tune and is EWS deleted!
This kit puts out around 290-300 rear wheel horsepower (340hp crank) on a healthy motor.
INCLUDED
- Vortech V2 S-Trim Supercharger (Rebuilt by Vortech)
- Dinan Supercharger Bracket Mounting w/New Hardware and New Powerdercoating
- Dinan Boost Intake Pipes w/NEW Powdercoating (Supercharger to Throttle Body)
- Dinan Z3M Specific Intake Pipes w/NEW Powdercoating (Supercharger to Air Filter)
- NEW K&N Air Filter
- Braided Supercharger Oil Feed Line + Banjo AN Fitting w/NEW Crush Washers
- Dinan Modified OBDII Oil Dipstick Tube + NEW Seal (not shown, but is included)
- Dinan Crank Pulley w/NEW 12.9 Grade Bolts
- Dinan Supercharger Pulley (D315-0306)
- NEW Gates Belt Tensioner Pulley (36094)
- NEW Dayco Tensioner
- NEW Dinan D862-4217 Supercharger Belt
- New Kayser Bypass Valve (good for 16psi+)
- Rebuilt Dinan/Lucas 28.8# Injectors (D1720BA)
- BMW MAF Extension Wiring w/Butt Connectors
- NEW Stainless Steel Radiator Mounting Brackets
- NEW Brake Booster Vacuum Tee w/Vacuum Hose to Bypass Valve
- OBDII Dinan Tuned M3 ECU w/ NEW Dinan T9 Scaler and NEW Harness - EWS Deleted!
- Diesel Mechanical Fan w/Dinan Extension hub
- All NEW Stainless Steel Hose Clamps
- Check Valve for Fuel Evap
- Check Valve for Oil Separator to Oil Pan Drain
- Check Valve for Valve Cover to Oil Separator w/NEW Silicone Hoses
- NEW Silicone Vacuum Line
- Dinan CARB Sticker
- Dinan OBDII Install Directions
PARTS NOT INCLUDED:
- Cruise control extension harness and brackets
Local pick up available in 93644
Not a Z3M but I just completed a Dinan kit install on my 98 M3 Sedan. Pics for expected results.
