Giving up on my dream build for now.
I would like to sell the full suspension as one complete package because it is fully assembled.
All parts are new unless labeled used:
- E46 M3 front calipers (used)
- E39 540 rear calipers (used)
- Caliper rebuild kits
- E46 M3 front brake rotors
- E46 325i rear brake rotors
- Hawk pads
- E30 ebrake rebuild, new shoes and cables
- Nasieg 5 lug swap kit with brake adapter brackets
- E36 M3 front hubs
- Z4 rear hubs, new wheel bearings
- 2 e30 rear axles (used)
- New Lemforder front control arms
- Treehouse front CABs, painted with POR-15 (used)
- E36 steering rack (rebuilt 15k ago by Rack Doctor, new inners/outers at that time)
- Modified steering joint for rack swap
- Stance coilovers (15k miles)
- Motorsports Hardware studs (4 new, 16 used)
- E46 wheels for rolling the chassis around (used, bad tires)
- Garagistic rear trailing arm reinforcements
- Garagistic complete chassis reinforcement kit
- Garagistic trailing arm mounting point reinforcement gussets
- Garagistic front control arm ball joint reinforcement kit
- Garagistic rear shock mount reinforcement kit
- Condor rear trailing arm bushings
- Condor DTM trailer tie down
- Condor rear subframe bushings
- Garagistic rear camber/toe adjustment kit
- New front and rear sway links
Asking $3000 for the complete setup. Located in Niles, IL.
I have well over $4500 into this setup.
Pics:
Before reinforcement/paint:
Thanks,
Matt
'91 Granit Sedan Turbo S52 | '13 Carbon Black F10 550iX MSport | '89 Zinno Sedan iX
Bump!
Thanks,
Matt
Bump!
Thanks,
Matt
Bump!
Thanks,
Matt
Bump.
Thanks,
Matt
Bump
Thanks,
Matt
Bump
Thanks,
Matt
does this work on e30 m3?
What are the chances this is still for sale?
