I need to change my oil level sensor. I'm tying to sell the car and I don't want this light scaring people off. I know that it is electronically failing as it showed up in my friends INPA software.
My oil is only a month old... Can I drain the oil, change the sensor, then use the same oil? Don't wanna spend money on over 6 quarts of new oil at this point.
Thanks for any advice!
Sent from my SM-G925T using Tapatalk
Yes, you can. I would suggest buying a brand new drain pan (less than $10) and making sure you keep it clean. Do this in a garage if possible.
What "thumbs up" really means
There is (always) another way. Use your old drain pan but put a clean plastic bag in it.
Charlie
Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
If it really bothers you, just change the 'oil level sensor'....or be honest, tell the perspective buyers why. If they are BMW savvy, they will understand.
as long as you keep it clean when it comes out there is no reason it cannot go back in. If it gets contaminated with dirt or other fluids then i would avoid reusing it.
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
I've removed these on other cars. I didn't drain the oil. I removed the sensor, quickly put my thumb over the hole, then put in the new one. Afterwards I cleaned off the oil that leaked with paper towels. Just have the replacement sensor ready to grab. If you're fast you only lose a very small amount of oil. Do it with the car cold.
