Results 1 to 11 of 11
Thread: 2002 BMW 325ci Coupe e46
    Nov 2017
    Northridge, Ca
    325ci, 740il
    Cool 2002 BMW 325ci Coupe e46
    Question-I need to replace my leaky valve cover gasket, and oil pan gasket. What brand to you recommend besides OEM? Should I use a sealant on the gasket, to make sure the gasket stays seated, and hopefully last longer? And what do you think a reasonable price is to have this done? Thank you
    Jul 2016
    Perrysburg, Ohio, USA
    1992 BMW 325i
    Quote Originally Posted by IndyCarSerious View Post
    Victor reinz is a good brand, I’ve never done the oil pan gasket but I know for the valve cover gaskets you’ll hear both yes and no depending on who you ask about rtv sealant or not, I did not use any on my valve cover and torque to correct specs and don’t have any leaks. If it was me I would do it myself as taking a bmw to any shop is going to cost and arm or leg in labor, so maybe buy a few tools and expand your mechanical skills and learn your car a little bit better, but that’s just me.
    Good luck!
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    If you don’t have a strut brace it’s an easy job. Bentley book says to use sealer on the places that have seams and on the rounded parts of the valve cover gasket.
    California
    325e 535i M5 325iT 330i
    Elring Klinger makes good gaskets. Factory workshop manual specifies sealant around the edges of the half-moon seals. I highly recommend Loctite 38364.
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Sealant on the half circles at the back and also where the vanos unit meets the head at the front. Also replace the 15 seals under the fasteners. They are needed for proper sealing of the new gasket and usually sold separately
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    make sure you rule out the oil filter housing gasket before you dive into the oil pan. Serious pan leaks are quite rare, and are frequently misdiagnosed when all it was was the oil filter housing.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Nov 2017
    Northridge, Ca
    325ci, 740il
    Thanks-I have both to replace both gaskets, plus spark plugs, and oil. Oh and new oil sensor. My mechanic is charging $975.00 cash.
    Nov 2017
    Northridge, Ca
    325ci, 740il
    Thanks. I have to have the bottom steam cleaned first before taking it in. Because of oil on bits and pieces. I know for a fact the valve cover gasket is leaking
    Nov 2017
    Northridge, Ca
    325ci, 740il
    Thank you
    Nov 2017
    Northridge, Ca
    325ci, 740il
    Thank you everyone. Lots of great help- Interesting I will be taking my car into BMW for recall on Tuesday. This is prior to having this work done. So it will be interesting what they would charge me? I'm having both gaskets, plus spark plugs, and oil replaced. Oh and new oil pan sensor. My mechanic is charging $975.00 cash. Although I bought an aftermarket sensor for $12-locally.
    Nov 2017
    Northridge, Ca
    325ci, 740il
    What BMW dealers are charging now! WTH?
    I was just at the BMW dealership for the recall they just had. And of course I got the 32 point inspection. I already knew things that needed done. Valve, and pan gaskets replaced. Spark plugs, and oil. I get the recommendation back, and it states "Replace valve cover gasket $2000.00" I asked the service vip WTF? he said it seemed a bit high. I asked, so what do your mechanics make now? $189.00 an hour he replied. I said my attorney cost that. With a straight face he replied "Well the BMW dealership in Beverly Hills charges $205.00 an hour. LMAO Good luck. My mechanic is changing both gaskets, oil of course, 6 new sparkplugs, and my oil level sender for $975.00. I got my own sender, so even that price will be going down. By the way peeps. If you have a leak under there. It needs to be cleaned ASAP. So the rubber bits don't get wrecked. So another $75.00 for a underneath engine carriage cleaning. Bugger me. But I have to! Hope that helps?
  1. 2002 BMW 325Ci Coupe 5-Speed $5500 OBO - GA
    By ChoeDaddy in forum 3 series & Z Series
    Last Post: 08-11-2013, 12:35 PM
  2. E46 2002 BMW 325Ci Coupe $6500 - GA
    Last Post: 02-22-2013, 04:16 PM
  3. E46 Exclamation FS:2004 BMW 325Ci Coupe E46 Black Premium+Sport Package
    By Rippin101 in forum 3 series & Z Series
    Last Post: 04-14-2011, 08:46 AM
  4. 2002 BMW 325ci cd53 e46 radio have aux?
    By Crispichickn in forum 1999 - 2006 (E46)
    Last Post: 10-30-2010, 06:25 AM
  5. F/S:2002 BMW 325Ci 2d Coupe
    By Suprajjang in forum BMW Cars For Sale / Wanted
    Last Post: 12-21-2004, 02:25 PM
