I drove my car this morning...went to back into the garage and the gas pedal must have become disconnected from the cable. I looked at the cable under the hood and it looks fine there. Is this a common thing for the cable to come loose at the pedal? I was able to back the car into the garage with the car at idle...luckily .
2000 Atlanta Blue Z3 2.5L 5 speed manual with factory hartop.
Replace this pn 35411152331
Its the grommet between the cable and the pedal.
I've had it fall apart when entering a freeway.. most embarrassing.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
It's issues like this that (more often than not) keep me from scooting out into traffic when there's just enough space--especially if there's a semi coming--thanks for the reminder.
35411164739 is the grommet for the other end at the throttle body, I think. It's not listed on realoem for all of the vehicles it should be. I had a bear of a time tracking that end down. I had to modify a different grommet to fit instead, so I'm going to order this one now that I remember.
Grommet No. 14 disintegrates:
http://www.realoem.com/bmw/enUS/show...diagId=35_0152
https://www.ecstuning.com/b-genuine-...g/35411152331/
That allows the cable to pull out of the pedal.
The black grommet and brass cable end are shown in the upper right of this photo:
BMW MOA 696, BMW CCA 1405
Thanks again for all the replies. Got the grommet ordered today.
