Results 1 to 10 of 10
Thread: Coolant hose extension?
    Apr 2013
    Los Angeles
    95' M3
    Hey guys I'm looking for this plastic coolant hose extension that connects my expansion tank hose to the spider hose.
    Anyone know where to find it?
    Wisconsin
    98 328IS 03 325xi
    Realoem.com? Just looked, are you sure it's not part of the expansion tank?
    Gave away my BMWs, driving a VW and an Audi now.
    mslevin's Avatar
    mslevin is offline Have you checked RealOEM? BMW CCA Member
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    #7 on this diagram. This is for a '93 325is but it should be the same AFAIK
    http://www.realoem.com/bmw/enUS/show...diagId=11_1142
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by mslevin View Post
    Or #8 here on a 98 328 http://www.realoem.com/bmw/enUS/show...diagId=11_1142
    Apr 2013
    Los Angeles
    95' M3
    Thanks for the replies guys. It's actually the little plastic piece that doesn't have a number between hoses 6 and 7. I've searched for hose extension, adapter, connector, etc and I'm coming up dry.
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    Dorman makes a bunch of universal coolant hose connectors. You can usually find them at any of the mainline auto part stores. I don't recall the ID of those hoses but take the old connector to the store and you should be able to find a match.
    Apr 2013
    Los Angeles
    95' M3
    Thanks Twistytee, I ended up at home depot today, went to their plumbing section and although I didn't find the exact sizes I needed, I found out what they are called.. Barbs. I specifically needed one that converted my 3/4" #7 to a custom 7/8" #6 I have routed directly to the waterpump. I found one here in case anyone else it. I bypassed the heater core and throttle body lines so no need for the spider hose.
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by shorvath011 View Post
    Maybe it was part of the hose, put the part numbers into ECS's website. They've got the best pictures of parts. That way you can see which hose it's a part of.
    Jun 2016
    North Carolina
    I replaced both of those hoses last fall and the plastic connector wasn't included with either part number. Mine was still in good shape so I re-used it, but it's a pretty generic piece so I'm sure the plumbing barb with hose clamps or a Dorman reducer connector from your FLAPS would serve the same purpose well enough.
    Wisconsin
    98 328IS 03 325xi
    IDK how the PVC will hold up to hot coolant, brass would be better, find barbs that adapt to pipe thread and make a three piece fitting. Might be easier than trying to find a barb with the two sizes you need.
  1. Coolant hose to the throttle body??
    By JT-KGY in forum 1992 - 1999 M3 (E36)
    Last Post: 06-02-2003, 04:07 AM
  2. coolant hose from throttle body
    By jbob in forum 1975 - 1983 (E21)
    Last Post: 12-27-2002, 05:21 PM
  3. Coolant hoses.
    By SilverE30 in forum 1983 - 1991 (E30)
    Last Post: 08-19-2002, 01:57 AM
  4. Ok, what is this on my coolant hose? (+ hose q's)
    By Ryan Stewart in forum 1983 - 1991 (E30)
    Last Post: 07-03-2002, 12:50 AM
  5. FS: New E39 540i coolant hoses
    By MONSTER in forum BMW Parts For Sale
    Last Post: 06-17-2002, 11:47 AM
