Results 1 to 17 of 17
Thread: Need SRS tool. Not INPA/laptop. $15 OBD-2 vs. $200 code reader?
    Feb 2009
    USA
    2001 530i (E39) 128k
    Bottom line, I want to reset my airbag light,
    and the $15 B800 reader isn't doing it.
    Can I buy something that does?
    I have a $15 Veepeak ODB2 reader.
    Use it with Torque and OBDFusion to read/reset codes.
    Works fine.
    I have an airbag light to reset and the $15 B800 reader isn't resetting.
    I do not want to install INPA on an old laptop (too big a project)
    I am looking at paying the dealer $150 to reset the SRS light anyways.
    Is it worth investing in a "next level" code reader?
    I noticed there are $200+ code readers.
    What special uses are they for?
    BlueDriver seems popular for $99
    https://www.amazon.com/BlueDriver-Bl...dp/B00652G4TS/
    I also see stuff like this in the $200 range
    https://www.amazon.com/Launch-Scanne.../dp/B00EN7JPIO
    Apr 2016
    Philadelphia
    1997 m3
    Any knowledgeable local shop should have a scanner with srs reset capability. Shouldn't be anywhere near $150. Don't just reset it, read the code first to see what its on for in the first place. There's a chance it'll need more than just a reset for the light to go away. If you're set on owning your own tool then the launch isn't a bad product, since it scans most of the modules on the car anyway. I've had a launch before i invested in a snap on and the launch worked fine.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    PA Soft will read and reset SRS codes as well as all other BMW specific codes. It also allows for limited recoding of certain modules. Try ebay.
    Feb 2009
    USA
    The light is not a legit code.
    I connected the battery while the airbag was off (window regulator replace)
    Feb 2009
    USA
    Quote Originally Posted by dhurley34 View Post
    I get the sense that these laptop programs are a nightmare to configure. (Need a win98 laptop, etc)
    I only would want something plug and play.
    If PA Soft is plug and play, can you post a link to a verified working seller?
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    Find someone with a SRS Peake Tool or buy one. They only work on the SRS system, but they work well.
    Aug 2014
    Lawrence Kansas
    Quote Originally Posted by OnTheFence View Post
    PA Soft is super easy to install/configure compared to the nightmare that INPA is. Just need a PC running XP. Not sure of trusted sellers, but I bought my version on ebay.
    Feb 2009
    USA
    No go, I am running Windows 7.
    I'd rather pay the dealer $150 than to deal with setting up some 15 year old laptop
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    I also have my SRS light on. I've read a few posts on this, but am still not sure what to do. I've pulled and re-plugged the plug under the passenger seat, with no results.
    I hate to spend $150 to get it fixed, if I could do it myself and end up with a useful tool. I don't like spending money, but if I can get a tool that does more, like engine diagnostics, I probably should.
    I am a DIY guy, and can even learn sometimes.
    I'm not at all a computer guy, so simple is better.
    I've read about the INPA setup, but it seems too complicated for me. I just read about PA soft, but don't have XP on any old computers
    There is this tool, which seems to be good:
    https://www.amazon.com/V7-0-Creator-.../dp/B00VSYZ2NC . Is this a good tool to buy? Is there a better one near that price ($64)
    Any comments, help, or advice is appreciated.
    Dec 2007
    Spain
    2003 330ci
    The airbag light won't go away on it's own.
    INPA is difficult for non-computer guys.
    PA Soft works for me on windows 10.
    Normal obd2 stuff won't work to reset the airbag.
    Carly for BMW (Android app.... maybe Iphone too??) works for diagnostics, coding etc... and will reset your airbag light. You will need the app and a cable from Carly. It's not as cheap as chinese PASoft cables, but won't cost $150 and you will have full BMW diagnostics and coding abilities on your phone. I personally find the app a bit irritating, but it does the job.
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    All the programs work fine in windows 10 with the right configuration(inpa, pa soft, ncs, etc). Inpa and associated programs use 16bit applications, 64bit versions of windows dont support 16 bit apps, so you need the 32bit version of the OS for those. PA soft is 32bit so it should work on any OS. My diagnostic computer has been running windows 10 32bit for awhile now.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Feb 2009
    USA
    Dec 2013
    Chicagoland area
    EXOTICS
    Oct 2016
    San Leandro
    2008 535i, 2004 328i
    Will this tool work with a laptop for an E46 and an e60? Read and reset codes? I'm looking for something similar to Volvo's VIDA program.
    TIA
    Dec 2007
    Spain
    2003 330ci
    Yes. Assuming it's all configured correctly, that should do everything you need.
    Oct 2016
    San Leandro
    Thank you.
    Oct 2007
    Middle TN
    Too many/Not enough
    ^^This^^...You will not find a better device at this price.
    chrome-extension://oemmndcbldboiebfnladdacbdfmadadm/http://www.foxwelltool.com/upload/pro/201604/foxwell_bmw_functionlist.pdf
    Current Garage:
    91 e34 M5 - spoiled & demanding 27 y/o -glanzshwarz
    91 850i/6 -another spoiled & demanding 27 y/o- schwarz-gone but never forgotten
    06 325i - undeserving, spoiled & demanding 27 y/o daughter's DD-hellrot
    03 MINI Cooper S JCW -spoiled & demanding, yet deserving wife's DD - Chili/Panther
    05 X3 3.0i -family workhorse - diamond schwarz
    12 X5 3.5d - torque monster - space gray metallic
    86 GMC Cabellero - Old Faithful 32 y/o DD BMW Support Vehicle
    08 Cub Cadet 19HP 46" hydrostatic- yard vehicle
    88 Schwinn Sierra - 1WD Off Road Vehicle
    e31 & OHC BMW CCA #385540
  1. OBD II resetter/code reader
    By DarKarTs in forum California sponsored by Avus Autosport
    Last Post: 03-26-2010, 05:23 AM
  2. need SRS reset tool
    By bungy42 in forum New England - US
    Last Post: 09-27-2004, 09:14 AM
  3. Need SRS reset tool to use...
    By Dinan M5 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 08-26-2004, 12:19 PM
  4. Need to borrow a Peake R5/SRS tool
    By thurst0509 in forum Texas
    Last Post: 08-01-2004, 10:44 PM
  5. Need SRS Reset tool in Bay Area
    By iwannadinanm3 in forum California sponsored by Avus Autosport
    Last Post: 07-28-2004, 04:11 PM
