Results 1 to 4 of 4
Thread: Steering wheel swap
    Nov 2013
    Southeast
    Steering wheel swap
    Looking to install a steering wheel and airbag from a 1995 e34 into a 1994 e34. When I removed the old wheel, I discovered that there is a significant difference between the slip rings. The old one has a carbon contact that maintains contact with the slip ring whereas the new one does not. Is it as simple as changing the slip ring or is there more involved?
    Jan 2017
    Amman, Jordan
    1995 BMW 525i Touring
    did you have an airbag on the old wheel?
    if not then you will need a slip ring for the new wheel, also you will need to remove the carbon contact and rewire the horn with a new connector for the slip ring connector. if you didn't have an airbag then the wiring for the air bag plus all the control boxes are probably not fitted in your car (but 94 models all came with airbags.) unless somewhere along the line someone removed the airbag and fitted a wheel with no airbag then you would probably have the connector on the column. (it's orange color).
    E34 525i Touring 1995, M52B28 LSD... fully restored.
    Oct 2003
    Seattle
    99 M3
    Steering wheel swap
    Realoem.com can help with the part differences. You may need the bracket that the mating contact is installed.
    Nov 2013
    Southeast
    The car currently has an airbag. It is the older style one with the solid black bmw emblem on it. Additionally, the slip ring does not have the wire that goes to the new style airbag.
  1. Steering Wheel Swap.....questions
    By m34fun in forum 1991 - 1999 (E36)
    Last Post: 02-11-2003, 05:39 PM
  2. Instructions for steering wheel swap?
    By JoeZ in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-19-2002, 09:04 AM
  3. Steering Wheel Swap - How To???
    By ///M3ryder NY in forum 1992 - 1999 M3 (E36)
    Last Post: 09-27-2002, 10:21 AM
  4. Airbag light came on after steering wheel swap
    By Dinan330ic in forum 1991 - 1999 (E36)
    Last Post: 09-10-2002, 07:41 AM
  5. E46 M3 steering wheel swap to E36 M3?
    By e36driver in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-06-2001, 12:11 AM
