Results 1 to 5 of 5
Thread: Blown fuse F63 of air-condition
    May 2015
    Lightbulb Blown fuse F63 of air-condition
    Hi all experts
    BMW E46 318I engine N42
    my AC climate unit does not turn on found that Fuse F63 was blown out , I changed the fuse and the fan blower does not start and when I press the AC button the fuse blown again.
    I need the wiring harness of the AC ,can any body post a screen shoot of it here?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Fuse #63 is for the A/C compressor relay. What I would do is see what is spiking on the relay. Not knowing if this is a euro spec or british spec, as the relay is in different locations AFAIK.
    What you can do is search for "BMW WDS" as that is the wiring diagrams for our cars. I have WDS only for offline on a XP Pro computer, otherwise it won't work.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2015
    than you for your reply, it this fuse for the relay circuit or for compressor circuit ?
    dworthy's Avatar
    Nov 2010
    Yes, it is. So you could have a relay gone bad or the clutch itself to the wire running from the relay to the clutch. I would say you have a couple of tests to perform to figure out what has gone bad.
    How I would handle it would be like this:
    1 Remove relay and see if the fuse blows
    2 Test relay while out to see if it is good
    3 Test the wire to the A/C compressor, but first unplug the wire.
    4 Lastly check the clutch.
    Good luck, I would say most of the time it is the relay.
    Darin
    Current:
    Past:
    M-Flight Member
    Los Gatos CA
    1987 325is, e34, Z3, e39
    I would start by checking the insulation on the wire on top of the compressor. The short wire from the connector to the clutch (wire coils under the pulley) often has cracked or entirely missing insulation.
    Another likely area for problems is the wire from the body to that connector. If it's routed incorrectly the insulation can wear through.
  1. Air conditioning blowing fuses
    By twozees in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-03-2012, 05:56 PM
  2. Air Conditioning keeps blowing fuse!
    By Cool 318ti in forum 1991 - 1999 (E36)
    Last Post: 09-29-2009, 12:16 PM
  3. Air Conditioning and Fuse Question
    By havente in forum 1988 - 1996 (E34)
    Last Post: 08-18-2009, 03:35 PM
  4. Help, my heating/air conditioning has a mind of its own!
    By VOLSBimmer in forum 1991 - 1999 (E36)
    Last Post: 05-16-2003, 02:45 PM
  5. Supercharger in place of Air Conditioning...
    By EMC in forum Forced Induction
    Last Post: 04-28-2003, 10:44 AM
