I'd like to put one in my 540i, and I know I can get one from a M5, but I'd need the M5 half shafts and modified half shaft. Are there any pumpkin kits available for a rebuild or did any e39 non M5's come with an LSD that I can search for?
'98 M3 5spd - '03 540it 6spd M-Sport
I’m also looking for an easy solution for this, but I don’t think it exists
Wavetrac, Quaife and one knock off brand, offer torsen diffs that bolt into the stock housing. Not super cheap though. I have the wavetrac and love it. No issues.
If you have an M Sport with the 3.15, the existing half shafts will bolt onto the M5 diff. You will need the rear section of an M5 driveshaft to attach to the front section of your existing one (if you're going to keep the auto).
I have an M Sport manual with the 3.15. Will the m5 diff just bolt on?
+1 to Wavetrac, super easy to install,
E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
Looks like this is a good option: http://metricmechanic.com/differentials/
If I read right, it’s $1500 for a fully built diff that will just bolt up.
I'll be getting myself a Quaife unit when the time comes...
Sent from my G8141 using Tapatalk
I have just bought it. Lsd 3.15.
e39 540i 6speed Supercharged,
E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
My install of Wavetrac unit to show what's involved. Not too hard of a job.
https://www.bimmerforums.com/forum/s...-DIY-with-Pics
Im not sure that's correct? I thought that was only if its' the TOURING with the 3.15, and not the Sedans? Correct me if I'm wrong. The driveshaft bit is exactly right.
The other supplier philly alludes to I think is Mfactory. AFAICT those seem to be Chinese built knock offs of WT/Quaife/etc. type diffs, although some BMW guys are running them, haven't heard that they are disasters...
Ha ha that would be sweet. Don't think so. See the note at the bottom:
Owner must provide their own Quaife Unit & Core
Please call for gear options & more information.
$1500 for them to install your quaife, in your diff. $2100 if you just drive your car in with a quaife in the trunk.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
I believe you're correct. I did not elaborate since it appears the OP has a touring.
Crap! You are exactly right. I knew it was too good to be true.Ha ha that would be sweet. Don't think so. See the note at the bottom:
I have been torturing my M5 diff (with Redline Racing Oils "NS" style lube in it), and it has been performing perfectly. Just throwing that out there as a data point. It really is surprising me how well it's working.
The helical gear diffs are a little bit different of a concept, and when they are good quality ones they work very nicely, but a little different in operation than a standard style "salisbury style" or whatever they are. But I like a welded diff very well, so maybe I'm not a good guy to listen to.
Yep a thing to know is some of the Torsen style do NOT like having a wheel lift and be put back down again, i.e. lift a wheel on the track under heavy power and it will shatter the spider inside when it touches back down apparently... Now for a street car or even a mild "DE" car thats never gonna be a worry but for a super hi-po application, you might be better off w the clutch pack style. On the other hand, the "torque biasing" type are AMAZING in the wet/snow on real streets and that makes them a better choice IMO/IME for real daily type cars in mixed seasons. My Touring is amazing in the snow for a big old RWD german hoonwagon which by all rights should be a bit problematic.
2003 M3CicM6 TiAg
Former:
I've got 2 spare M5 half shafts, PM me if there is any interest.
Sold them back in 2018.
https://youtu.be/KSyP6OvzlTs
What do you guys think about this?
