Results 1 to 11 of 11
Thread: Stomp Test Not Working
    Nov 2017
    Livingston, Michigan
    1995 BMW 525i
    I bought a 1995 525i yesterday, and today when I went to do the stomp test, I couldn't get it to work at all. The check engine light didn't blink at all on any attempts. Here's a video of both me, and a friend attempting it. Any help is appreciated, thanks!
    https://youtu.be/q099PTgaZKQ
    https://youtu.be/ZAn3Fju6wxs
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Did you do it fast enough? The 5 stomps have to be in less than about 2 seconds I think and you need to start stomping as soon as you turn the key to position 1
    Nov 2017
    1995 BMW 525i
    Everything I've read has said the key should be in position 2, is it supposed to be in position 1? And from the videos I watched, I'd say I did it plenty fast, but I was hoping someone could watch the videos I recorded and tell me.
    Nov 2009
    Realville
    93 525iT,91 318i
    It is Position 2, I'm sure that was just a typo. Book says 5 stomps to the floor and released within 5 seconds of key hitting position 2, which is the " run" position, but engine not started. Generally, if the test isn't working, it indicates a problem with your tps, but it does sometimes require a bit of finesse.
    Nov 2017
    1995 BMW 525i
    Can you watch the videos I posted and tell me if I'm doing it correctly? I just went out and tried it again about 15 more times and couldn't get it. I'll have to check the TPS tomorrow though, thanks.
    Mar 2014
    Texas
    97 528, 95 525, 03 525
    Exact same issue here. Couldn't get stomp test to work. But that being said, my check engine light was not ACTIVELY on. I just saw that it came on during a drive, and turned off after 30 seconds. So it could be that there are no codes?
    Nov 2017
    1995 BMW 525i
    From what I understand you should be able to do the stomp test regardless of your check engine light being on, and there being no codes. With no codes, you should be able to do it normally and get the 1444 "No Fault Codes" code. I'm just repeating what I've read though, this is my first car, haha.
    Mar 2014
    Quezon City, Philippines
    '89 535i/5, '88 735i/5
    If you have a WOT switch/kickdown switch at the end of the pedal travel, you should be hitting that at every stomp.
    Zionsville, IN
    93 740i, 84 533i
    It is possible your kickdown switch is bad or wires corroded.
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    Nov 2017
    1995 BMW 525i
    Turns out there was just a ton of slack in the throttle cable. Tightened it up and got the stomp test to work on the first try, and to my surprise, the 312k mile car threw no codes.
    Nov 2017
    1995 BMW 525i
    Just realized my Check Engine light is still on even though the only code I got was 1444. Any ideas what could cause this?
  1. Help a noob - '92 525 no-start, stomp test not working
    By mdimillo in forum 1988 - 1996 (E34)
    Last Post: 02-06-2014, 03:49 PM
  2. OBDI Stomp Test not working
    By dlight26 in forum 1991 - 1999 (E36)
    Last Post: 01-17-2013, 08:57 AM
  3. Stomp Test not working?
    By Speede7 in forum 1995 - 2001 (E38)
    Last Post: 03-25-2012, 11:43 AM
  4. Stomp test not working
    By sse34 in forum 1988 - 1996 (E34)
    Last Post: 01-27-2011, 03:34 AM
  5. "stomp test" not working?
    By sanid98 in forum 8 Series (E31)
    Last Post: 11-30-2009, 07:39 AM
