Results 1 to 2 of 2
Thread: E30 - Brake Light Issue
    Oct 2017
    New York
    318i 1992 Vert
    Angry E30 - Brake Light Issue
    I was working on replacing the brake lights, and I had an issue.
    I bought these aftermarket lights and one of the wires were sticking out. The wire touched a piece of metal and now that specific bulb does not turn on. Its the idle brake light, the one that lights up whether or not you're touching the brake pedal. This is on the driver side and I tried testing a different brake light and that specific one still didn't work.
    I checked fuse #23 in the front and its not blown or anything. I don't know what else to do.
    In fact, I got pulled over for it, and now I have a "Get it fixed" ticket.
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    This is the rear light that turns on when you turn on the headlights, correct? Run a patch wire from the passenger side tail light. Janky, but it'll get you passed the fix it ticket quickly.
    And then you can hunt for where ever you shorted the wire, or more likely not.
    And post pics, no one knows what aftermarket lights means. There are tons of options so you're not really giving us a lot to work with, besides the fact that you broke something.
    If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
  1. brake lights issue...
    By CurtisC7 in forum 1983 - 1991 (E30)
    Last Post: 12-25-2004, 03:48 PM
  2. Third brake light issue
    By motosport3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-29-2004, 12:35 PM
  3. brake light issue
    By towncarblue in forum 1992 - 1999 M3 (E36)
    Last Post: 08-24-2004, 01:24 AM
  4. brake light issue
    By nateb in forum 1983 - 1991 (E30)
    Last Post: 10-29-2003, 12:05 PM
  5. Brake light issues
    By E36Shikara in forum 1991 - 1999 (E36)
    Last Post: 06-13-2003, 07:26 PM
