Ive acquired a groaning noise that seems to be coming from the passenger side rear wheel. I serviced the diff a couple of days ago with 75w-140 and still have groan noise. Are these diffs rebuildable or hunting down a used one a better option? Would this be a good time to put in a non LSD with a different ratio or stick with what came on the car?
Does it groan all the time or just when making slow tight turns?
"The US Olympics bobsled team has renamed their sled 'Biden' because nothing has taken America downhill faster"
TheStigg (aka "gale")
92 735i 5-spd, turbo pending
89 535i 5-spd (may she rest in pieces)
94 325ic 5-spd
87 325is
Slow tight turns only.
Sounds like a wheel bearing......
3.15 lsd is a very desirable diff even if you decided to replace with a different diff your diff with noise still has significant value. You can use any diff from a 740i/l or 540 just know if you use a 740 diff (2.93) I believe? Your going to lose off the line acceleration
Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
G/F’s E34 92/ 525iT + F48 18/ X1
I'm opening her up tomorrow and checking the bearings. I'm very suspicious its a possible bearing.
Groaning like that sounds more like a stick-slip instability condition in the LSD clutch pack, which is a common problem with clutch type LSD's. Rather than tear it down, do another drain & fill and put a full 5 or 6 oz. bottle of LSD conditioner in it and do a bunch of tight figure-8's in a parking lot to work it in. It should resolve itself without a tear down.
94 325ic 5-spd
87 325is
75w-140 with the additive did the trick. Thanks to all who chimed in.
