I've owned a couple e38's and wanted to pick up a e31, I found one with 200k and it's looks to be in good shape, how much is it worth? I've seen people ask some high numbers on these cars even when there beat up.
anywhere from $3000 to $20,000. How about year?, is it a V8 or a V12?, manual or automatic?, does it have maintenance history?, are there any mechanical, electrical issues? Just because it looks "in pretty good shape", doesn't mean a lot if the car doesn't run right. If it is in top notch condition mechanically and cosmetically, then it will command a higher price (despite the 200K mileage).
2001 740iL - Titansilber
ALPINA B7 -Alpinweiß III
1994, v8, automatic, 2 owners and a few maintenance records, he says there's no issues with it just minor wear on the interior, hasn't sent pics yet to determine, im guessing it has a leak or 2.
By this time the timing chain guides should have been replaced. If not, then you may be in for some fairly major engine work. Having owned and E38, v8? I'm sure you are familiar with this type of maintenance.
Current
95 e31 840 Ci (Auto) Orient Blue 61k
11 e90 328i Space Gray
18 F15 X5 35i XDrive White
Past
00 e38 740 i (Auto) Titanium Silver
94 e31 840 Ci (6 speed conv.) Avus Blau (This car was Awesome!)
03 e46 325 Ci (Auto) Jet Black
91 e31 850i (Auto) Diamond Black, Yes, two!
00 e39 528i (Auto) Jet Black
92 e36 325i (Auto) Laguna Green
'94 840 has M60 in it. Timing chain guides are not an issue in that case.
WBR, Tony
But it would be a Nikasil block, and possibly a California car all its life... So in those cases just have a compression check on all cylinders. Might be a good bargaining chip if the numbers are low or all over the place. Then swap in an M62 or S62
Also note the transmission should be a non-triptronic ZF 5HP24 (black label), which requires the special Shell ATF (Turner has an equivalent now). Do not treat this black label tranny like the E38 green label 5HP24 transmissions. Different programs, different friction setup.
2006 R53 JCW (British Racing Green) - 1994 E31 840Ci 6spd (AVUS Blue)
2021 F56 JCW (Rebel Green) - 2000 E38 740i Sport (Titanium Silver)
2017 F26 X4 M40i (Carbon Black) - 2007 E91 328iT (Deep Green)
2012 E82 135i M Sport (Marrakesh Brown) - 2015 E84 X1 (Cashmere Silver)
2005 E53 X5 3.0i Sport (Kalahari Beige) - 2000 E36/7 M Roadster (Oxford Green)
2000 E38 740i Sport (Oxford Green) - 1999 E36 M3 Coupe (Fern Green)
1995 E31 840Ci Canadian (Oxford Green) - 2000 E36/8 M Coupe (Oxford Green)
2004 E46 330Ci (Oxford Green) - 2001 E36/8 Z3 3.0i Coupe (Oxford Green)
2002 E39 525i Sport (Oxford Green) - 2002 E36/7 M Roadster (Oxford Green)
2001 E53 X5 3.0i Sport (Oxford Green) - 2007 E63 M6 (Silver Grey)
1995 E31 840Ci (Oxford Green) - 2006 E86 M Coupe (Sepang Bronze)
2001 E39 530i Sport (Aspen Silver) - 2009 E92 M3 (Space Grey)
2001 E38 740i Sport (Sahara Beige) - 2008 E92 M3 (Melbourne Red)
2000 E38 740i Sport Canadian (Sahara Beige) - 1997 E31 850Ci (Jet Black)
Mine is for sale, 97 840 with 165k miles.... drove it to California and back this summer!
https://wichita.craigslist.org/cto/d...384680937.html
Kyle
88M3, 97 840Ci.
