Results 1 to 11 of 11
Thread: Schwaben scanner
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    Schwaben scanner
    Recently I purchased a Schwaben scanner to check my steering angle sensor. Everything I try to click on says the it is not connected. Is this garbage that I should return?
    Jan 2014
    USA
    04 ZHP, 83 320i, 00 M5
    Ecstuning owns and makes that brand. They make good stuff. Call them and ask their techs for help.
    Robert
    Jul 2014
    Westfield, IN
    '91 e31 M70
    Quote Originally Posted by charter21p5 View Post
    Robert
    Ecs does not manufacture that unit. Foxwell does. You normally have to go through a connection process to the vehicle first before you do anything else.
    You can search for issues connecting to your vehicle using foxwell as a keyword and you will likely get the results you need.
    '07 e65|N62 - Alpina B7 - Black Sapphire|Black|Loaded|GONE
    '02 e46|M54 - Orient Blue|Beige|'Vert|GONE
    '00 e39|M52 - Anthrazit Metallic|Grey|GONE
    '01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line|GONE
    '91 e31|M70 - Schwarz|Schwarz|M70|FOR SALE
    '13 328i Auto - Black Sapphire|Coral Red|Sport Line|GONE
    '05 545i SMG - Jet Black|Black|Bamboo Anthracite|GONE
    '07 335i Auto - Montego Blue|Grey|GONE
    '05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|GONE
    '97 528i Auto - GONE
    Wadsworth, Ohio
    BMW
    Looks like you have an 02 E46, if you have a 20 pin diagnostic socket under hood try using the adapter and going in via that. Some cars require going via the 20 pin instead of the obd2 port.
    -James
    Sep 2008
    Sandy, Oregon
    I don't have this connection. I did with my E36. I also have a Peake tool for both the engine as well as the SRS system. I purchased this unit because people online wrote that you don't need a Windows laptop to use the unit. Apparently you do. I have a Macbook, a Macpro, and a Macbook Pro as well as an ipad. Apparently what I was told was wrong and a person has to have a Windows PC to set it up. Is that true? Because if it is it is useless to me. I did consult with your chat feature about this. Can I make any use of it without a Windows PC?
    Please contact me. I realize that this is a big weekend.
    Jul 2014
    Westfield, IN
    '91 e31 M70
    James - all e46s we’re equipped with OBDII and do not have the 20 pin connection.
    Curry - you only need access to a Windows computer to update the software on the scanner. It should operate fine connecting directly to your car via the OBD port.
    Sent from my iPad using Tapatalk
    Sep 2008
    Sandy, Oregon
    That's the issue. It doesn't work as described. Everything I click on gives a no connection signal. It won't load anything.
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    return that, get a launch connector and for the price of the connector you can unlock two brands with the purchase price... download the app from the appstore will do everything you need to get done on an e46 easy for less than 100 bucks
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
    Ohio, USA
    1994 318is
    I have had the ECS Schwaben scanner for almost two years and have never had an issue with it. It is very nice for the cost. Are you sure your ODB port is functional? I would test the Schwaben scanner on another vehicle before giving up.
    Sep 2008
    Sandy, Oregon
    My Peake tools with an adapter, as well as my regular OBDII tools all work when using the port. Sadly they won't read the Steering angle sensor. My VAGCOM tool reads it, but it can't change it. I don't think there is anything wrong with the connector in the car.
    It won't even read the VIN number. The unit must be defective. I'll contact ECS on Monday.
    Sep 2008
    Sandy, Oregon
    I had to return the unit. At least they were polite about it.
  1. Schwaben scanner question
    By fairchild in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-23-2017, 01:46 PM
  2. for sale : printer scanner fax
    By Ferrarokid in forum BMW Parts For Sale
    Last Post: 07-19-2002, 03:37 PM
  3. police scanners
    By black325 in forum Off-Topic
    Last Post: 06-20-2002, 07:58 PM
  4. NE1 have the june 2001 issue of bmw car and a scanner?
    By Cosmos///95Lux in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-12-2001, 03:17 PM
  5. ODB Scanner Is here --- My thoughts
    By JamesB in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-03-2001, 10:09 PM
