Results 1 to 8 of 8
Thread: Trouble-Shooting Driver's Seat
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    The driver's seat on my car had already been unbolted and unplugged from car when I bought it. I don't know if PO was going to try and repair it or not. I pulled it out to make it easier to work under the dash when I removed the GM.
    I wanted to re-install the seat last weekend but its a bit jacked up. Seat rails and lift mechanism are uneven. I have removed seat rail assembly and used a drill to adjust the rails a bit as Tom suggested. I have removed cables from motor assembly and they appear to be long enough to engage motor/gearbox.
    Can the motor be powered up with 12v to see if mechanism is working properly?
    I have also removed the lift cables and one appears to be too short with only a 1/4" or so protruding from the sheath so I will adjust the sheath on it and probably take a bit off on the other side.
    Would like to test both mechanisms out of the car if possible. Any suggestions or recommendations would be greatly appreciated. Thanks,
    Sep 2011
    Vancouver Canada
    '91 850i, E39 & E46 Cars
    JDP530- You should reach out to the E31 Seat Guru: Paul Brill
    seatguru429@gmail.com
    He is also on this forum as Seat Guru.
    Dec 2013
    San Antonio
    Quote Originally Posted by henryc View Post
    Thank you!
    Sep 2017
    Worcester Ma
    1994 840, 2002 X5 4.6is
    Plus one on Paul. His front seat cable set and instructions made quick work of the seat repairs.
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Usual problem with the seat rails is a broken plastic gear, not the cables. If you are the only driver you could just adjust to your liking and leave it.
    Dec 2013
    San Antonio
    Quote Originally Posted by BMSman View Post
    Where are the gears located? The only gears I could find easily are under the plastic cover on the 'voltage regulator' connected to the motor. And they appear to be find. I just tested the cable mechanism with a drill and one rail moved evenly but the other side did not so there must be a gear in rail that is partially stripped.
    I went back and re-read a few threads and found info on gears you are referring to. Just got the internal assembly apart and found split gear on spline shaft. What are the sources for this 17t gear? Thanks,
    May 2013
    Salinas CA.
    1993 BMW 850CI
    Quote Originally Posted by JDP530 View Post
    Google Odometer gears bmw E31 seat gear.
    Dec 2013
    San Antonio
    Quote Originally Posted by Mikekugel View Post
    Odometer Gears can make a replacement using your gear for a mold. He doesn't keep replacements in stock but his delivery time is only a week or so once he receives gear.
  1. Power Seat Trouble Shooting
    By bdspilot in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-11-2016, 12:08 PM
  2. Heated seats trouble-shooting
    By shawgf in forum 1983 - 1991 (E30)
    Last Post: 04-17-2011, 04:04 PM
  3. Please help me trouble shoot-- seat bushings
    By Eric In Sac in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-15-2006, 04:27 PM
  4. Clunking/sliding drivers side seat fix???
    By KmanM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2002, 05:26 PM
  5. Driver's seat, Door pin
    By mrdenial in forum 1991 - 1999 (E36)
    Last Post: 01-27-2002, 10:50 PM
