Results 1 to 11 of 11
Thread: Need help removing parking brake cable from 323I
    Corona California
    79 320/6 81320i 65malibu
    I for got how to remove the parking brake cable from the spreader in the wheel. Can not find info on how to do it.
    Thanks.
    Feb 2009
    District Nine
    sold 78 BMW 320i
    I forget too! The e30,e36 parking brake is similar. Something like this: Disconnect the cable at the hand lever, remove the lower spring (9) from the shoes (possibly remove 10, 11 also), separate one of the shoes from the spreader, wiggle the spreader out of there and disconnect the cable from the spreader. May have to completely remove the brake shoes
    http://www.realoem.com/bmw/enUS/show...diagId=34_0340
    Tbd
    Jul 2010
    San Jose, California
    E21 320i, E30 325i
    '81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    If its a drum brake--you take off the nuts to the parking line your changing attaching it too the parking brake lever in the cab of the car, raise the car in the rear-chock the front tires, remove the the tire on the side of the parking brake line your changing, remove the drum and remove the drum pads-hardware and all-disconnect the parking brake line from its expanding lock then pull the line out, install is reverse. Looks like remove the support bolts as well.
    Randy
    Jun 2016
    Austin, TX
    1978 323i
    Corona California
    Quote Originally Posted by cgifool View Post
    Thank you!!
    Dec 2017
    Rowley, MA
    1983 320is
    I'm trying to remove the entire rear disc braked 323i subframe from a 320i. The only thing left is to remove the emergency brake cbles. I did the swap about 15 years ago and the 323i subframe is going to be put into another 320i. I've removed the cables from the handbrake handle but I can't recall how to remove the entire cables from the body. Can anyone help my failed memory?
    Jun 2016
    Austin, TX
    1978 323i
    Here's how I did mine:
    Disconnect the brake-end of the cable (these are the steps shown in the attached images above)
    - remove the calipers and rotors
    - use a hex key to turn the parking brake shoe retainers 1/4 turn and remove
    - use a vice grip to remove the lower parking brake spring
    - pull the parking brake shoes apart at the bottom and remove upwards
    - pull apart the actuator thing and push out the little button that secures the brake cable to the actuator.
    - remove the two lock nuts securing the brake cable to the backing plate
    - pull the cable out of the backing plate so it flops free.
    - unclip the cable from the hanger that is attached to the trailing arm.
    Remove the cable from the car - this was the hardest part from me, the ferrule was corroded to the cable tube
    - spray the ferrule with some penetrating oil
    - grab it with some vice grips and wiggle wiggle wiggle, back and forth and back and forth while pulling out on it. it should gradually work looser and looser and finally pull free.
    If the nylon/plastic covering over the cable is all broken on the cable, you might consider cutting it where it comes out behind the ferrule, and pullign the cable out of the car from inside the car. Then remove the ferrule last.
    Hope this is helpful! I wasn't sure what part you were having trouble with.
    regards
    David
    Dec 2017
    Rowley, MA
    1983 320is
    Thanks, cgifool. Part I'm having trouble with is removing the cables from the metal tubes going into the body. Found this old thread with lots of ideas and think I can handle it from here: https://www.bimmerforums.com/forum/s...e-Cables/page2
    Dec 2017
    Rowley, MA
    1983 320is
    Jun 2016
    Austin, TX
    1978 323i
    Crusty!
  1. need help! Wheel + parking brake stuck/locked up
    By Robp074 in forum 1991 - 1999 (E36)
    Last Post: 12-05-2018, 07:43 PM
  2. HELP! Trying to remove parking brake cable at rotor
    By Copenhagen944 in forum 1991 - 1999 (E36)
    Last Post: 10-14-2014, 02:02 PM
  3. How to remove parking brakes cable from trailing arm???
    By DJ Genius in forum 1991 - 1999 (E36)
    Last Post: 02-05-2008, 05:32 PM
  4. Need help removing Pioneer head unit from E36
    By Cary328is in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-09-2006, 11:52 AM
  5. Need Help Running My Rca Cables From Deck To Floor
    By valkyrie98 in forum 1991 - 1999 (E36)
    Last Post: 10-08-2005, 08:28 PM
